2009 Chevy Tahoe Driver's window switch problems
Tahoe_SSV
Northern New Hampshire
So, my Driver's window switch isn't working properly. It will roll down the 2 rear windows, but the 2 front windows...Nothing. The passenger switch works fine and if I put passenger switch on drivers side it will roll window down. I took switch apart and cleaned the switch housing, the pad, plungers and all the contacts. That didn't work. Any ideas?
Geotrash
Dave
Richmond, VA
+1 to what @intheburbs said. Super easy to replace but you'll need a Tech 2 to program the new one to your truck.
LordWayback
Isopropyl alcohol if that doesn’t work new switch/wire pigtail my pigtail in my passenger side is giving me issues in my 01. etc etc
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
He can also roll the dice and try to find a used switch from a a similarly equipped truck and it could plug and play without the programming. I was able to do this finding one on eBay.
Tahoe_SSV
Tahoe_SSV
My drivers side switch will operate all windows accept for driver window. If I put passengers switch on drivers side it will work. Do I have to replace the whole unit? They are ridiculously expensive. At least 100 bucks.
89Suburban
SE PA
Are you sure it's not the regulator?
89Suburban
SE PA
My used one I bought a year ago was 90 bucks, I feel you. And I had to ship it in from Texas junkyard.
LordWayback
never had a door wire harness go bad, it's always been the switch/regulator/motor
Passenger harness is bypassed from the previous owners that’s why my power door locks won’t work unless I hook the jumper wires into power again.
vsaravia
