Stupid strut nut: install on bilstein 5100?
LaxCoachT
Hi guys...
Struggling to get the 15mm strut nut installed on a new set of 5100's.
I'm reusing the top strut mount and insulator, and the nut is really recessed in the mount. I can't grab it with anything (wrench, pliers, needle nose, etc) and hold the top 6mm flats on the strut shaft at the same time.
Seems like the nut has a locking peen, pretty difficult to turn once the thread is nearly fully engaged. Tried the impact but the shaft just spins.
I've been looking for one of the cutaway sockets but 15mm is smaller than anything I've found online (schwaben etc)
I replacing the whole suspension with Moog upper/lower arms & springs, has been pretty easy until now...
Nothing on YT, seems like every clip I've seen skips over assembling the struts...
What's the trick?
Ted
I've never done one of these, but something like the Lisle 63400 tool might work. Someone with experience will contribute, I'm sure.
Well Ted, you obviously didn't read my post when I did this back in 2021! LOL
Go underneath the top mount and through the coil spring hold onto that shaft with a pair of vise grips (with leather to keep from marring up the shaft) and then you can torque it down to 44 foot pounds. If your insulator is in good shape, it will be a pain to fold/roll out of the way to get the vise grips in there.
Welcome to the forum!
L
LaxCoachT
Thanks for the tips...took a look at that thread Swath, I'm trying not to rip he boot, want to keep the new england salt off things as much as I can
I think the Lisle 20400 is what I need. Calling my parts guy tomorrow to see if he can get one.
Just Fishing
Can't fix stupid
Utah
one of mine fought me.
I ended up allowing the spring to have a little more pressure pushing up on the plate than I would have liked, then hit it with the air impact to zip it off.
I had to slowly reduce clamping on the springs while I did it.
Singing the "Doing some sketchy shit" song. ;)
I aimed the spring in a somewhat safe direction, and away from my shingles...
I stayed away from the bottom of the strut while doing it.
:ehcapt:
The correct tool sounds much safer.
:yaoface2:
PatDTN
:ehcapt:
:yaoface2:
Yeah I put my big impact wrench to work on one of mine. I learned the shaft unscrews part way down the shaft.
Dustin Jackson
Hi guys...
What's the trick?
Ted
View attachment 375477View attachment 375478
@LaxCoachT I ended up grabbing the top with vise grips and using an open ended wrench and going around it at an angle. Certainly wasn’t the best method, I’d do what the other guy said lol
jz57
Should be an easy job. Using an offset wrench and a crescent wrench to get job done.
L
LaxCoachT
Guys: For what it's worth, the Lisle 20400 did the trick.
Not super hi-quality tool (steel's kinda soft on the piece that goes over the end of the strut shaft), but it got the job done.
Was pretty inexpensive too.
Charlie21ny
