I suspect BCM... thoughts?
TrybalRage
I've owned my 2010 Suburban 2500 for maybe 9 months now. I've had intermittent no start (won't crank) issues that I've always related to the battery. The first time it happened, it was also throwing all kinds of errors - 4WD, stability, ABS, etc. The shift position wouldn't display correctly. The rear hatch was inoperable. None of the gauges displayed that I can recall.
Replaced the battery and all was well.
Since then, on occasion it wouldn't start. Turn the key, power on everything, go to crank, everything goes blank. It would never jump without first removing the negative battery terminal first (in retrospect, I believe this was resetting the computers).
I figured it was a parasitic draw somewhere so I got in the habit of keeping it on a battery tender. Figured I'd get around to fixing the issue one day. I don't drive it often so it wasn't at the front of my mind.
Well earlier this week, twice it left me sit after being parked out in the hot sun for 6 hours or so (I usually park in my garage). Both times I got jumped, including having to remove a battery cable first.
So yesterday I start trying to find a parasitic draw. I was using the current draw method across my fuses, and on all the fuses I could check I'm showing 0 millivolts of activity. (Also, I've been keeping it in my garage and it's been starting fine when I do try). Well I had to run out at my lunch break, so I fired it up and went out to the store. On the way home, I heard a slight pop from somewhere inside the dash and all of a sudden the same errors - service 4wd, abs, blah blah. All gauges go dead except for the voltmeter. I can't be sure but it felt like much reduced power. Luckily I wasn't far from home.
Pulled in the driveway and started fiddling with things, turning it off and on, and it would restart fine several times until it suddenly did the black-out no crank again. I grabbed my voltmeter and checked the battery - 12.7 volts. So I simply removed the cable and attached it again, and it started up - no more errors.
So now I'm thinking I don't even have a draw - or if I do it's not my primary issue. I suspect the BCM may be bad, and it is being especially affected by heat. Before I start chasing down this rabbit hole, does this sound plausible? I don't own a tech2 so it would probably just be off to the dealer, unfortunately.
T
TrybalRage
On a side note, this truck was previously a "commercially owned" vehicle - to whom exactly I have no idea. But off the same harness that plugs to the BCM I found a bunch of cut wires... any idea where these are supposed to go?
gpracer1
Phoenix
Could be brake controller wiring, need to follow it or put a meter on it and see what does what if you hit the brakes, etc.
T
TrybalRage
It goes right into the under dash harness. Someone on FB suggested it was there from factory for people who wanted to run an aftermarket brake controller.
But I'm not sure this is causing my intermittent black-cluster no start condition.
Possibly a bad ground or corrosion in the battery cables. Check to see if it looks like any of the cables have internal corrosion present where they attach to the terminals at each end. Also inspect at the **** fuse, remove everything and clean it up. Check any grounding points, there might be corrosion. Also sometimes the under hood fuse box gets corrosion underneath where it plugs in. You can tap on it with a mallet using a block of wood on top to see if any problems change for the better or worse or remove it and inspect underneath- it unclips and then you can lift it up. Electrical issues are a PIA.
T
TrybalRage
Yeah I've been digging though other posts and it seems that grounds grounds grounds always comes up. I've already inspected all the main ones in the engine bay and they're in good shape and clean and tight. But I saw in one post that the factory negative cable was failing even though it looked fine on the outside.
For $50 or so I'll give that a shot first.
The 4 wires you showed in post #2 do appear to be the OE wiring for an aftermarket brake controller. As long as they don't touch any other wires, it shouldn't cause any issues with anything else. The red wire is fused, and if you're not going to use a brake controller I'd advise to disconnect it from the side stud in the underhood fusebox. eTrailer has videos on installation and they show the stud locations.
petethepug
Michael
SoCal
As a matter of required general maintenance the battery grounds should be replaced. They rot from the inside out effectively acting like a backed up pipe. Essentially it drains slower & slower until it’s time to call a plumber when it doesn’t.
The presumption of the BCM failing goes hand in hand with the grounding issues. The boards get cold joints. The price of replacement is so inexpensive that it doesn’t make sense not to swap out both when the signs are there.
$129 for a coded replacement BCM.
That's not a bad price, since a new, uncoded BCM costs about $75. So a $50 programming fee is quite reasonable.
I do not see them listing a 2011 Suburban, much less a 2500, and they don’t even do BCM’s if they did, they do engine computers (ECM/ PCM) only from what I can see. Your data is off. I have replaced the BCM in my 08 Silverado and programmed it myself with my Tech2 and a used BCM cost me about that much, without programming.
The correct PN for a 2011 2500 Suburban is 25835966. I have seen them on eBay, reman, programmed, for about $200. I’ve never seen one for $129, that would be a steal. If you have a link, please share it with the OP. Otherwise you’re just blowing smoke.
Link for eBay programmed 25835966. You need to look at the superseded parts list in the listing, you’ll see this one in there.
Actually, Joseph, new BCM’s for the NNBS are closer to $200. Search GM 25835966, the correct one for the OP’s truck. I noticed this because I’ve replaced mine in my 08 Silverado and remember it wasn’t cheap. I ended up buying a used one.
T
TrybalRage
Yes, that is the PN for my existing BCM. I've also seen them listed, coded, from Garrett Tuning and Highway 71 Auto Parts (although they actually list a different PN that they say is compatible). I don't know how good of a vendor either of those places are.
petethepug
Michael
SoCal
I know of them because they 2day shipped a BCM for an 07 Esky last month. They don’t list every vehicle they work on, they specialize in the service not the parts.
Call them after the holiday. I wouldn’t steer you wrong with a solid for a good recommendation or a even a wrong data accusation if the vehicle they supplied it for wasn’t cured with similar symptoms.
Just Fishing
Can't fix stupid
Utah
Go at the grounds first for sure.
I went through some mud and started having issues until I cleaned the undercarriage.
it was really weird.
gauges turned off while driving, lights lit up, stalled, etc.
Hosed down where the bcm stuff grounds out to and all was well.
Later I took the grounds and cleaned them.
Then later still, I did it once more and cut the shrink tubing back on each one and flowed flux and solder into the joint.
One of them was really bad.
I had to break out the "Stay clean" copper pipe flux to fix it. :jester:
That stuff works fantastic on really dirty connections, however the instructions on the bottle say to not use it for that...
I flush that crap out with brake clean and electrical contact cleaner after I'm done. :headbang:
intheburbs
SE MI
I find it highly unlikely that any intermittent problem is computer-related. They either work, or they don't.
This is completely and utterly a bad electrical connection issue. I'd even replace both battery cables. Check the primary feeds to the alternator, to the mega fuse holder, and to the load center. You checked grounds? Check them again.
And yes, those wires in the footwell were for a brake controller.
T
TrybalRage
New ground for battery to passenger head and to frame coming today. Other main ground was braided cable from rear drivers head to firewall, and also checked one under driver's footwell at the frame. My truck is pretty corrosion free and the connections are tight.
While I'm in there I'll take them off and sand/wirebrush the connection points as a double-check.
What I don't understand is that when the problem(s) occur, a quick disconnect and reconnect of the battery and everything is set right again. That's what was making me think computer related - like it was being reset.
intheburbs
SE MI
Low voltage and/or loose connections cause a myriad of issues.
Looking at the problem in a more macro sense, take it to an auto parts store and have them check the battery and charging system.
How old is the battery? If it was me, I might replace just for the peace of mind.
T
TrybalRage
Battery is about 6 months old. Was the first thing I replaced when all this started.
When charging, the alternator is putting out 14v+.
JamesinAbilene
