Service stability message
1968fury
Hi all,
In may of 2018 I discovered the pitman arm seal was leaking in our 05 Yukon xl so I replaced the gearbox. Since then the service stability message popped up and when I had the truck aligned since I also replaced one outer tie rod end too, the shop tried to get rid of the message. I had the battery disconnected for a day and it still comes up.
Hi all,
Do you know anyone with a bi-directional scan tool like a Tech-2 or Snap-On Solus? Need to see the Chassis codes, what is causing that light to stay on.
moto
