low/no oil from Jiffy Lube and what next?
Z15
Michigan ,USA
Its easy to clean up an oil mess with a can a brake cleaner. Does wonders, never know it leaked and evaporates fast and leaves no trace.
I would never trust a place to use a container to pour in oil, if I don't see the bottle I don't trust they are putting in what they say they are. That;s like a diabetic trusting the soft drink from the fast food joint is really sugar free version. I had a intern working on my GPS survey crew one summer who worked at a quick lube and what they did there was bordering on fraud at times. Pouring in bulk 10W-30 because the were out of 5W-30 and with the managers directions, no one every knew.
PS - I would not tell the dealer about this, they may document it and use it against you in the future if problems arise.
DenaliCountry
I wouldn't say a word to the dealer about this situation. For a little CYA I would actually go so far as to remove any indication that your GF used Jiffy Lube (remove the window stick, any receipts from the car etc) and take it to the dealer to have the oil changed by them ASAP. If there is any short or long term engine damage where warranty comes into play I am certain they would check the system to see when the oil was last changed and if done outside the dealer they will likely test the viscosity of the oil and if JL used some random weight oil you'll be on the hook for the repair.
The stuff I have heard about at these quick lube places, as others have stated, is borderline criminal. Had a kid I knew in high school that worked at one and if they didn't have the right filter for a car (say an Audi or BMW) they would grab the next closest one and force it on, cross thread and all. That's one of many stories.
macman1234
My wife had a similar incident with her 2007 Yukon XL. She went to Midas for an oil change. Midas changed the filter.. But they forgot to refill the oil. Wife drove about 7 miles or so home. Low oil light goes on and truck is knocking away. She called me. I told her to check oil. Dry dipstick. She called Midas.. They came to my home to fill up the oil. My wife filmed it... Motor sounded fine afterwards. Midas offered us a free oil change. I immediately took it locally. Had mechanic change oil. I asked him to save the filter, save the oil in the filter and the first quart of oil out of the pan. I sent the filter and all of the oil to an oil analysis testing lab. They were able to provide me with a very detailed breakdown of 21 different metals found in the oil, including iron, copper, chromium, aluminum, etc.. plus and a visual evaluation of debris found in the filter.. including Major contaminants (measured in microns) like Aluminum flakes, varnish (results of high temps), Minor like Iron, dirt & grit and trace amounts of Carbon, fiberglass, cellulose, etc. The final verdict; Elevated metal wear indicated ABNORMAL & EXCESSIVE wear.
The testing lab is: Oil Analysis Labs, 2121 East Riverside Ave, Spokane, Washington 99202 Phone: 509-535-9791 or 800-366-8596.
Bottom line: Midas fought me about providing new engine.. Once I showed Midas the report, they agreed to replace the engine..
justchecking
Military
SW Ohio
And stay away from Walmart. I could post experiences here but you can see those on you tube.
steiny93
I've worked at a few dealers and I managed a dealers quick lube for a bit in a past life.
For the record, all quick lubes have issues (dealers, jiffy, all of them).
A couple questions
- Exactly what light came on?
- Are you absolutely certain they dumped 8 qts of oil into that engine? Is it over full now?
A loose oil filter makes a terrible mess, you absolutely would notice that being parked in your garage.
If the engine was drained of oil, fresh oil filter their is no way it made it 600 miles and their is no way the dash wasn't lit up with a low oil pressure light.
Perhaps the 'leaking' started all at once, like on the highway right before the light came on.
If you take this to the dealer and talk through the situation expect to loose your engine warranty if anything happens later. That would be totally fair as GM didn't cause this rather Jiffy did and you'll be battling with your insurance company and Jiffy which is going to suck.
If it was me.
I would get back down to Jiffy Lube with your girlfriend and the truck. Show them the pictures (proving the 8qts went in) and have a discussion (with manager or owner) around what they are going todo to either ensure no damages occurred or take care of damages. From my perspective I would separately get an oil analysis done on the oil (after it has gotten some miles on it). I don't think I would wrap the dealer into this mess yet as right now you don't know anything.
If it really didn't have oil for 600 miles (which isn't possible as it would have had a low oil pressure light the entire time), that engine is toast. Typically when you loose oil pressure you have seconds to get it shut down before bad happens. Without oil pressure bearings are moments from failure when they are under load at temp.
randeez
south florida
friend had a legit chevrolet dealership do this to him, filled with 6qts, oil light came on within 10 miles of driving it though. put a qt in showed nothing on the stick, another qt got it barely on the hatch.
he called and bitched at them, was probably just someone used to putting 6qts in an ls for 15 years.
Stbentoak
A huge difference though, @steiny93 is that if a dealer did this you have a lot more legs to stand on, and access to factory engines and mechanics and further warranty, vs other places that may want to fix, but on their own terms and people.
Jonmurphy
ok, so how did they determine it was a jerry can low on oil then? nobody in there right mind just adds 8 quarts of oil to a engine with knowing the existing oil level first, which to me indicates that they drained it and replaced the filter previous to adding the oil.
you know what I mean you don't pull into a shop and say hey my oil is low ummm ok lets just add 8 quarts of oil that should fix you right up sir....or mamm rather, that just doesn't happen.
Yeah this is a weird story complicated by a woman that has no idea what's going on
Geotrash
Dave
Richmond, VA
This thread is why I still do most of my own oil changes. That and the fact that I had a Walmart overfill my nearly new Subaru by at least 3-4 quarts several years ago. This was in the days before smartphones so I had no way to document it and I was 250 miles down the highway when I discovered it.
I guess the old adage still holds true: If you want a job done right you have to do it yourself. If I do have a shop do an oil change for me, I check their work before I leave the parking lot.
Corning, New York
First- new guy and thanks ahead of time for any assistance!
Okay, kind of a weird one here. Some of this doesn't add up, but I know what the end result is, so my main question is what can I do about this now, and is there any legal recourse with Jiffy Lube?
2022 Tahoe 6.2 belonging to my girlfriend. currently about 15k miles.
-she had the oil changed last week on the 31st.
-About 6-700 miles on the car since the oil change.
-She called this morning frantic that her oil light came on. Instructed her to pull over immediately and check it, but she proceeded about a mile or two down the road back to the jiffy lube since it happened to be so close.
-JL informed her it was actually empty and that it took all 8 quarts to fill it up- she has pics of this happening and they admitted it was 8qts "low".
-They sent her on her way with hardly even an apology, and refused to document the incident on paper or in their system- although she took some pics of it happening.
-They claim it was a loose oil filter... but after I crawled all under the car this afternoon, there is not evidence of any sort of an oil leak, especially 8 qts worth. Its immaculate underneath. In addition, there has not been a drop of oil on the concrete driveway.
-I don't believe the car could go 600 miles with no oil in it, but... I have no other explanation as it was certainly not a normal leak. Again the truck is spotless underneath... So I am presuming it was never filled up (but 600 miles empty?)
So now what??
-IF the car could go that long with no oil, how much long term damage is there?
-I don't understand why the oil light just now came on? again, zero signs of a leak, but was certainly empty when got there. If it was a catastrophic oil dump that triggered the light, why no signs of leak? bad sensor? maybe guys lying and drain plug fell out- even so, I would think there would be some splatter underneath?
-Is there any recourse with JL for the damage done, even though its not manifested yet?
- I am considering a dealer trip to see if they can document anything with a computer scan. Although, I doubt they would be willing to state anything about damages.
Again, I know this sounds off, but I've checked and double checked for leaks and they dumped 8 qts in it today, and its topped off just right when I checked it after.
thanks yall. And I know... stay away from the fast lube places...
It seems as if maybe they completely changed the oil to cover their tracks. It would register low before being empty. And it would seem that the engine would contain a certain amount of oil even when it alarms for low oil/low oil pressure. I would be all over the corporate number for JL. Sorry for the luck.
CKendrick
