Diode Dynamics SS3 LED Fog Light Kit 2015-2020 Yukon
CMoore711
Not sure how long these have been out but they look to have great performance.
Have a molded trim piece that fits right into the OEM GM rectangular fog light housing location. They're a bit more pricey than the Morimoto XB's but have significantly more light output and like the Morimoto XB's they're a more fog light focused light pattern which would be much better than stock and more functional light over throwing LED's in the stock fog light housings.
Has anyone installed these or had any experience with them?
Xsbank
Morimoto S are crap. I have them on my Denali and I have flashlights that put out more light. That’s twice Morimoto has gotten me, I put their fogs on my F150 and they were even crappier! I may be a slow learner but if I didn’t say it before, here it is again: Morimotos are crap!
Tiki
Interesting. Was about ready to pull the trigger on the KD Fab brackets and Baja Designs dual lights. Hmmm.
Found this in an eBay listing before KD started making brackets and think it looks pretty good and like the idea of running a wide angle fog a d driving light.
CMoore711
CMoore711
I too like the idea of running both a fog and a driving light for function. I think that type of set up would be best to run them on individual switches so that you could choose to run which light in certain conditions. Then I would probably have one amber set of lights and one white.
This thread here has a few pics of other dual pod light set-ups in the factory fog light location: https://www.tahoeyukonforum.com/threads/finally-upgraded-my-fogs-to-rigid-d2.115716/page-3
Most of these dual pod set ups to me look like they're just a little too crammed in there. Sure they can fit in there, have been made to work, but they're crammed in there tight and almost look like they barely fully expose the whole lens of both pods out of the opening unless perfectly mounted. At least from some of the pics it appears that way to me. I could be wrong.
These pod style lights have more of a "rugged" "off road" look to them. Which is not a bad thing; I just don't think that fits the overall look of my Denali. Which is what keeps drawing me back to the set up here from Diode Dynamics I linked in the OP. The molded surrounding "trim" of the pod I feel is a cleaner way to integrate a single pod set up into the factory fog light location.
There is no denying their performance! They pack a huge punch in light output for their size, especially the Diode Dynamics SS3 MAX lights. I especially like that the SAE Fog light models have a focused fog light beam pattern (despite not being projectors) with a cut off that allows them to be very wide, and not put out unwanted glaring light too high for oncoming drivers.
The Diode Dynamics have a lot of engineering and design into their lenses, this provides a lot of different options and flexibility in changing the light output color and light pattern without having to completely purchase new pods.
Check this out:
I'll tell you what..... I just installed their fog bulbs ($90 for a pair) They are by far the best fogs I have ever owned. I'll post a pic soon.
I have the SS3 max on both my yukon and my silverado they kick @ss, work flawlessly, I also have the fleece "all lights on" board installed so fogs stay on with high beams
the best thing about the ss3 max is they are configured as a fog beam (wide-beam) so you can see about 40 feet or so on each side of the road.
and yaa there not cheap about $500-600 but it's all visual pleasure :Big Laugh:
here is shot showing headlights only, then headlights+ss3 max.
CMoore711
CMoore711
Thanks for posting those pics @Doubeleive . The width of the fog light pattern is insane on those!
I did end up ordering the kit linked in the OP in the white MAX version. Just in a pile of parts for a “front end refresh” since I have to get the front bumper resprayed. Excited to get them installed.
What about this fleece “all lights on board”? Do you know if they make the board for the K2XX Yukon?
I was looking at this harness here:
Thanks again for posting the pics!
works on all from 07-20, takes like 2 minutes to install including taking it out of the package, lol. It just allows the fogs lights to be on with the high beams, it is not a 6-high mod. fog lights continue to operate just like normal as well (with running lights, low beam, and then with high beam) the difference being they stay on if you flash to pass.
CMoore711
CMoore711
@Doubeleive coming through like the first of the month! Thanks man!
Those fleece boards are significantly cheaper than the harness I linked and seen pretty simple to install.
Tiki
I’m buying to Pros in yellow as well, just waiting for their next 15% off sale. Wish they offered the Max in a kit. Looks like I’ll need to do the Fleece product as well
BlackYukon
I'm kind of a Retard
Any updates or synopses from the people who have bought these? I'm Highly considering buying a set of the max fogs during their upcoming holiday sale. I'v owned the Morimoto fog lights for almost a year now and have only turned them on a handful of times because of how little the light output is.
CMoore711
CMoore711
I looked into the Morimoto’ s and from pics posted just wasn’t impressed.
I have the max white version sitting in the garage waiting to install. In the box they seem like quality units, light housing and trim pieces seem legit. Was highly considering getting the amber version and putting clear lenses on them for more of a 4000K output.
Tiki
I’ll post some pictures. They are worth it.
Tiki
DD SAE Pro fog lights. Photos show as follows: fogs, fogs, fogs, headlight, headlight + fogs. Very happy with the results as they preform exactly as advertised. I run these on the highway and have not been flashed, the cut off line is extremely sharp. I am considering swapping out for Combo beam pattern covers as I could also use down the road light as well as getting the Max level light. Oddly enough I asked about Max level when this kit was first posted and they advised Max was too bright.
BlackYukon
Very nice, thanks for taking the photos. I ended up ordering the max white fogs, so that's kinda unfortunate to hear. Hopefully since they have a tight cut off I can aim them lower to avoid flashing. I'v had extremely bright fog lights in the past and had to do the same.
I have the max on both trucks, never been flashed they adjust perfectly fine
Tiki
Bought Max for my truck, all the lights!
12lbs boost
The Morimotos are nice, but I don't like the smoked look when off. I do like them when on however. My wife's 2016 escalade has the oem multi leds and look/ work great. The Morimotos look like a smaller version but the smoked case looks like it should go on a kids subaru wrx sti.
Conedaddy
