What is the best way to seal aftermarket head lights?
What led's are you running in your fog lights.
I actually bought some LED pods to replace the fogs.
autvivid 2pcs Auto 6.3" 18W Flood... https://www.amazon.com/dp/B00XL70YKA?ref=ppx_pop_mob_ap_share 20220508_123739.jpg
I'm gonna replace them eventually, some have burned out because of moisture. I never sealed them with silicone.
T
thingraylinetah
Crossville Tennessee
Everyone tells me I am crazy because I want to lower my 4x4 tahoe but if I do a 2/4 drop in the rear or something there abouts it should still have plenty of ground clearance.
davidavidd
CO
Hello, butyl sealant tape this is the best sealing method I have found so far. However, keep in mind that all lights must have a breathing hole for condensation to escape through, usually a circular hole covered with a black membrane. There are NO vacuum sealed lamps o_O
Product:
To seal the lamps you need the butyl tape and a heat gun (or a hair dryer as a homemade solution). The tape softens like putty, you seal the lamp, and then the butyl hardens again. To open the headlights, repeat the process in reverse.
PS: Use gloves, is a very difficult material to remove from your fingers and nails.
T
thingraylinetah
Product:
Thanks for the good advice.
Candielaine
