AT4 3D Printed Items Thread
Fast_AT4
Fast_AT4
RWM +1
SW Florida
GM really didn't think things through when they made the center console safe. It's just an open box with no dividing compartments, whatsoever. And the sliding tray has to be removed each time I access the safe, because you can't lift open the safe door without hitting it on the tray. If someone (wink-wink) made a 3 or 4 way divider that fits inside the safe (1 divider for coins), it would eliminate the need for that top sliding tray.
I dont have the safe feature, mind snapping a pic for reference?
Fast_AT4
Fast_AT4
RWM +1
SW Florida
Holds $12.50 in quarters.
I do like my pinball :head3:
Fast_AT4
Fast_AT4
RWM +1
SW Florida
That looks pretty good. I’ve given up on the armrest charger possibility, as the hole isn’t wide enough for an iPhone 13 Pro Max in a case.
I’m going to do an attempt to sketch what I was thinking for the wireless charger bin. I have no CAD skills. Think something like a fully enclosed baby crib with legs on each end, so the phone goes on the wireless mat, this “baby crib” goes over the phone and is supported on the ends by legs slightly longer than the phone thickness. See sketch.
So to use the wifi charging pad, you would need to remove the "baby crib" feature, place the phone on mat, and then return the baby crib? I wonder if your "mat" area is the same size as to the AT4. That rubber mat just pops right out. Maybe remove it, place a ruler next to it (width and depth) to show the size reference.
WalleyeMikeIII
Sunny and Snowy Minnesota
Yes, that is kind of what I was thinking...unless you have a better idea.
Let me see tonight if I can remove that thing, put a ruler next to it and get some dims...
robbrown415
