No start issues again
RET423
Okay, the shop did not replace all of the components to restore your security system to functionality; it sounds like they attempted to wire a permanent resistor into the ignition to "spoof" the BCM.
That is why the yellow wire was disconnected, they didn't "forget to hook it up" because it is part of a harness that is either plugged in or not plugged in; this is a common bypass for a dead VATS system but $2000 is enough to easily buy the new tumbler and keys; if they charged you 2k for a hack that they didn't even do correctly you need to stop using that shop.
Your options are.
1) pull the column apart and restore the wiring to stock, then replace the key tumbler and do a security relearn.
2) pull the column apart and do the resistor hack correctly, then do the security relearn.
3) find someone with a program like HPtuners that will go in and disable the VATS system permanently in the programming (this is the best solution for an old creaky VATS)
If done correctly the resistor hack is pretty reliable and costs about 1 dollar, but the number of people that cannot seem to get that hack right is astounding; your story is not uncommon.
rockola1971
Indiana (formerly IL)
Your options are.
VATS(which came out on the 86 vette) is an entirely different anti theft system than Passlock 1 & 2. He doesnt have a resistor on his key so he has Passlock which is a magnet and hall effect switches. A resistor will not trick Passlock.
Phisher
Phisher
Winona Minnesota
I've done what everybody has said and this vehicle still does not start it is going to the junkyard because I'll get more satisfaction I think watching it gets smashed at this point thanks everybody I appreciate everything oh and trust me I stopped using that shop typically I don't use a shop this was the only place in my town I could find that was not a GM shop that could do the padlock fix according to them and obviously they didn't do it right and they won't stand behind it after a month and a half but again guys thank you
MassHoe04
Western MA
Satisfying to crush it? Maybe.
But that is a lot of money already spent on the vehicle purchase, parts and repairs.
That truck is worth much more sold to someone who might be able to fix it or have the time to part it out.
I understand the frustrations and wanting to go out with a bang (or loud crunch), but financially... Crushing or sending off to the scrap yard for a couple hundred bucks, doesn't make any sense to me. That's a wast of a good truck and a lot of great parts. Engine, transmission and transfer case alone are worth at least $1,000 all together. Maybe more! Doors, fenders, grille assembly, hood, glass, interior parts... Sitting on a gold mine.
Do what you feel you need to do, but I can't see literally throwing all the money you put into into the crusher. I would think you'd want to recoup as much as you could and sell it off at least.
Sorry you couldn't get it running. I know somebody out there probably could get it going, if given the opportunity to buy it from you.
rockola1971
Could be just a bad BCM also since the Passlock system inputs to the BCM. This whole system is stupid easy to troubleshoot with a voltmeter. Its seriously not rocket science. Id get a used BCM off Ebay or salvage yard before I even thought of scrapping a vehicle I just dumped 2k+ into.
Phisher
Phisher
Winona Minnesota
Yeah I get where you're all coming from but any of you want to buy it I'm serious you guys more than happy to sell it to any of you I'm in Minnesota this is supposed to be my everyday driver I'm a single dad like I said earlier and I need to get something rather than dumping money into this I've got to buy a vehicle before they're all gone
rockola1971
Its likely going to be ALOT cheaper to fix what you have than buying another used vehicle (AKA someone elses problem they sold off).
I've done this passlock reset several times and it does nothing I can't get the security light to do anything it's either off which I just realized now that there was a blowing fuse for the radio so I replaced that now the light comes back on but it's off once I shut the door so I'm at the point I'm just selling this vehicle I think
you have to think like a blind man when telling us what the problem is OR make a video and upload it to youtube and link the video here in a post.
have you done anything that was previously suggested? like verifying the starter works? what happens when you turn the key? does the starter run when you turn the key?
let's start again right there
1. starter verified working? yes/no
2. starter runs when I turn the key? yes/no
exp500
See post 39. Did you fix yellow wire? Does your anti theft light blink pattern change key off key on?
Radio removed? Fuses all checked? Post pic(s) of wires at column that are disconnected.
Phisher
Phisher
Winona Minnesota
All right so this is going to more likely be my final post yes the yellow wire is connected the security light is off I still do not have a running vehicle or starting vehicle I don't care if it's cheaper to get it fixed I have no money I'd rather ride my bike at this point then stare at it sitting in front of my house again anybody who says it's going to be cheaper why don't you buy this from me then instead of telling me how much cheaper it's going to be to fix
Phisher
Phisher
Winona Minnesota
I understand it'll be cheaper but I don't have that money I have no money at this point I have the yellow wire hooked back up I've got the pass lock to turn it off there's no security light blinking unless it's at the appropriate time the only blowing fuse was to the stereo which I've replaced so there's no blowing fuses now and I still have nothing that starts it turns over and continues to turn over I spray it with ether it doesn't even choke so at this point I don't care anymore the thing needs to be gone
Phisher
Phisher
Winona Minnesota
The starter runs perfectly fine all that happens when I put the key in is it cranks over and over and over if I spray it with ether it doesn't even choke it out it just continues to turn over and over I've replaced the fuel pump I've replaced the fuel filter I've replaced the fuel relay the starter is brand new I have 12 volts going everywhere it's supposed to be I have nothing happening other than it turning over no start whatsoever I've had a mechanic come over he can't even figure it out he says sell the thing junk it stop dealing with it I've got the security light to stop blinking except when it's supposed to blink I don't know what more to do and yeah I know coming on here is like talking and describing to a blind man but this is the only option I have I cannot afford to take it to a shop which I've already done twice it's cost me over $2,000 to get it fixed for a month I can't continue just fixing it for a few days I need a running vehicle for a daily driver that's what this was supposed to be that's what I was assured I was buying when I bought it obviously once again I got duped
Phisher
Phisher
Winona Minnesota
If anybody wants to call and video chat with me while I attempt to get this thing running again I'm more than happy to do that my phone number is 507-459-0912 anybody call me I don't care I appreciate all the help from you guys that you've given me
ok that helps, so the next thing to check is if the injectors are getting power, if not then there is a short in the harness or the ecm/pcm is commanding them off or a fuse is blown.
something of that nature.
that needs to be checked to proceed further, I would try and invest $300 in a tech2 clone before trashing a whole vehicle, you might end up needing a tech tool to find the root problem. even if saving $300 takes a while sometimes it does, being broke is expensive.
Phisher
Phisher
Winona Minnesota
There's absolutely no blown fuses I've pulled every one of them and the only one that was blown was the stereo which I replaced I'm not going to invest any more money into this it's going to the junkyard. 2 months ago we hooked it up to the tech two tool so that they could reprogram the passlock BS and put a new ignition in and obviously that didn't work because here we are again and I'm not going to pay to have it done for a third time it can go to the junkyard like I said that's where it belongs you know not to harp on the same subject but I'm a single dad of four who just lost his wife work on my own I can't afford this I will rather bike than put any more money into this *************
Phisher
Phisher
Winona Minnesota
According to my friend who's a mechanic that put his diagnostic reader on there the BCM needs to be replaced
I've been there, I have 5 kids and have spent a great deal of time with no "mom" around, I am not as broke as I used to be but I have been there as well.
not sure how it was determined the BCM needed to be replaced but if that is the case then you can get one for about $100 or less used, the catch is it will need to be programmed to the vehicle it won't just plug in and work. you would need to look at the numbers on the existing bcm and match it up with a used one.
rockola1971
Earlier on he had said plugs were pulled and were wet.
Charlie21ny
