2022 Yukon Tow Mode
GMCnewbee
Just wanted to quickly report on the Tow Mode I used last night. We have a 2022 Yukon Denali 2WD. My boat and trailer are only about 3,000 lbs but I wanted to try the Tow Mode to see what difference it made. What I noticed was the transmission definitely stayed in a lower gear at all times. My cruising RPM was up around 1800 no matter what my actual speed was. That is the beauty of a 10 speed transmission. The drivetrain has a lot of options for optimizing speed, RPM, and torque output. When not in Tow Mode my RPM is always lower than that. Needless to say, it towed like a dream with that light load but burned a little more gas. I'm sure that I could do just fine in Normal drive mode with my little boat.
altona
Parrish FL
I have read that the reason you should tow with the TH mode on is that the slightly higher RPM's helps to cool the components better. Also, the alternator puts out more which you will see on your battery volts gauge with the reasoning being you need more energy to run extra lights and brakes on the trailer. Also, the exhaust brake function becomes active in TH mode.
GMCnewbee
GMCnewbee
Thanks, I need to keep reading the Owner's Manual to pick up on some of these details. I forgot to mention that there is a noticeable difference in the shift points as well, they are a little higher, which makes sense.
On the GMT900s, the owner's manual said that Tow/Haul doesn't provide a benefit unless you were at 75% or more of GCWR. Check your owner's manual for the shift schedule, pretty cool. My 2009s transmission shifts funny towing heavy without Tow/Haul activated, with it on, it feels normal.
R32driver
I did my 2nd tow with the new yukon yesterday. Small car hauler with a small car (mk2 jetta coupe) and power wise it was great, no worries at all. Made the rear sag pretty good so that will need to get addressed but the ride was smooth overall. Short tow, 17 miles exactly and got 13.4 mpg
Lakerider
Following...boat season is coming and I'm around 5,000 lbs...
R32driver
squat squat...Don't mind the pile of **** i'm hauling (parts car for my GTI) but I doubt that trailer and car weigh even 5k lbs
SSGUNNER
interesting Ive seen a few with a similar squat on the road. Last week saw a similar yukon hauling a 7 seater UTV with similar squat. Im guessing the load leveling is what causes the squat. Then again i saw a Tahoe earlier this week not hauling anything with a similar squat…
DenaliCountry
With air ride there is no squat. I believe the rig pictured above does not have air ride. When I pull my enclose snowmobile trailer there is no squat, however, I have air ride which auto levels the vehicle with the extra weight.
R32driver
Correct, I do not have air ride. I have the ZW7 suspension which is not ideal for towing as it's super soft. Level kit possibly makes the sagging a little worse. If I did any amount of regular towing or heavier towing this would not be the rig of choice
Stbentoak
While you "Can" tow with this vehicle, it's not really a good towing vehicle of any substance. Air ride does help. If you are occasionally towing a boat or towing a trailer around the local area, yes, no big deal. But if you regularly want to go cross country with a reasonable travel trailer or the like, you would be much better served by an appropriate truck (3/4 Ton Min...)
WalleyeMikeIII
Sunny and Snowy Minnesota
Got my boat out of storage yesterday, it weighs around 4500 lbs loaded. Tongue weight is about 600 lbs.
Hooked it up, squatted for a bit, then the air ride kicked in, lifted it up level again, zero squat.
6.2 Denali drags the boat like it isn't even there.
Realizing that i'm still 3500lbs under the max tow rating of 8000 lbs, I think its a great tow vehicle if you stick to the capacities in the trailering guide.
Agree that if you are towing heavy, at/near max, a 3/4 ton or 1 ton pickup is a better option.
TFL truck took a High Country Suburban up the IKE gauntlet w/ a 7000lb Horse Trailer behind it, and they were impressed.
I think Air Ride and Max Tow are requirements on this thing if you are towing though.
BadDaddy2003
