alpha_omega
Michigan
any recommendations for a battery powered impact that can do lug nuts off & back on?
I’ve used all the big name brands (Milwaukee, Makita, Dewalt, Ridgid) and have had the best luck with Milwaukee. Buy once, cry once with regards to cost. You won’t need their heavy duty version to remove lugs. They will easily come off with the standard impact and a charged 5.0 battery.
My impact is the older generation, so things may have changed since then, but I’ve been happy with their 1/4 & 3/8 speed ratchets, the stubby 3/8 impact and the 1/2 mid-torque impact. The latter of which I’ve used to remove balancer bolts, along with rusted on suspension hardware and cross member bolts.
alpha_omega
Michigan
they had a bunch of different combos, some only had the little 2.0 battery, I have a smaller 18v black & decker impact and drill already for the light stuff for as cheap as the B&D stuff is it holds up fine I have a tendency to be rough on tools, I did have one of the black decker impacts go bad on me about a year and a half ago but a replacement was only $20 and I already had the battery and charger it got stripped out internally or something it just quit impacting.
Sounds like the impact wasn’t brushless.
Whichever brand you go with, make sure you get their top tier grade and you shouldn’t have a problem. Milwaukee has a line called “fuel”. There are Milwaukee M12/M18 tools and Milwaukee M12/M18 Fuel. There is a substantial difference. It’s like buying a John Deere lawn mower at big box store vs. buying one at a dealership. Same color, different internal parts.
alpha_omega
Michigan
I think you'd be happy. I have all 4 sizes. Everyone I know with milwaukee are happy.
For comparison, just in case you want the big boy 1400 ftlbs. This is surge 1/4" hex, 3/8" compact, 1/2" mid torque, 1/2" high torque.
You and I would be dangerous together. Remind me to never take you with me to do any tool shopping.
alpha_omega
Michigan
The free replacement batteries for life is what originally sold me on Ridgid cordless tools many years ago. The batteries are the most expensive part of the kits when you start talking the bigger or higher amp ones. They’ve been great tools. I have used Milwaukee and Bosch at work, Milwaukee is awesome but the most expensive which didn’t matter because the company was responsible. They switched over to Bosch because of price and ended up giving away all the Bosch and buying Milwaukee all over again because the drills were junk (couldn’t tighten the chuck) as well as a few others issues. The Ridgid drill I have tightens on even big ass bits super good, never had the chuck slip. The skilsaw is awesome too as well as the 1/4” impact I have. I was looking at the pics of the new batteries and they look like they’ll fit my existing tools, they say they work on all 18v Ridgid tools. I’m pretty sure Milwaukee’s new batteries won’t fit their older tools. Seems these companies like to change battery designs every few years do you have to buy new batteries, but maybe since Ridgid has to replace them for life they have incentive to keep them the same.
The new Milwaukee batteries will fit their older tools. The only problem with their batteries are the big boys 9.0 and 12.0. They won’t charge on the old chargers and they are the only batteries you want for some of their tools like the worm drive saw, their outdoor power equipment (leaf blower, chainsaw, weed whip). Otherwise you will drain the 5.0 and 8.0 batteries QUICK.
The mid and high torque impact will work with the 5.0 batteries, but their is a night and day difference when you put in a 8.0, 9.0 or 12. The weight of the 12.0 is stupid heavy compared to the tools and can be really awkward. With my M18 tools I run 5.0 in almost everything and 8.0 in the mid-torque.
Every battery and fuel tool I’ve ever had an issue with was replaced no questions asked - same as you with the Ridgid. And like you mentioned, once you commit to one specific brand it’s expensive to switch.
alpha_omega
Michigan
Except evap. It will never set, maybe in 2-3 months…:rolleyes:
I could never get my Silverado to set that one. After 2 months I registered it in a non -smog county.
Wait what? There are different rules for different counties? It’s not the same across the board for the whole state? Does it matter where you live with regards to which county you register in?
alpha_omega
Michigan
Ok…makes perfect sense. And you can then drive across that invisible county line and not require their “stamp of approval” for the tune you just installed, so long as you pay their county for the inspection?
*or more strict rules depending on which direction you drive. Legal extortion, what an interesting racket.
In Oregon, the smog testing is only done in the 2 major metropolitan areas-Portland and Eugene. Outside of those cities, there’s no requirement. Our neighbor to the north, Washington, quit testing altogether last year. They said cars are now clean enough that they don’t need to be tested. California should take note. And no, it doesn’t matter where you live here. It matters where the vehicle is registered. I can use my brothers address to register my trucks to, and since I’m the owner they send the paperwork and tags to me at my home. There’s an option to send the paperwork to either location, as well as a one-time option so you can have them sent anywhere at the time of registration.
pwtr02ss
Tennessee
well got 1/2 the order, going to have to try and judge how much to use for lug nuts one review said A (auto) setting and then use a torque wrench, A setting is just low rpm it doesn't really give a range of force, 1/2/3 are just increased rpm 300/600/900
Nice! That looks nearly identical to the milwaukee. Even has the same modes! If it works anywhere near the same, you won't be disappointed
Passed smog and I put the BB tune back on
the evap still wasn't set but it wasn't pending any code I started it up last night let it warm up and twice in early in the morning, you are allowed 1 unset sensor in Ca as long as everything else is good
That’s what I was wondering, if you’re allowed one. We aren’t here, and it’s stupid so I just said f*ck you guys I know how to get around this. Now I don’t even mess with getting smogged. They forced my hand lol.
In Jersey every one has to be ready. Anything over 25 yrs old doesn't need inspection.
Just Fishing
Can't fix stupid
Utah
Here it's over 30 is exempt.
last time i had smog done on the hoe, i noticed they had the obd2 check, and they had a sniffer in my exhaust...
Probably just that one shop.
+I was watching them like a hawk. :jester:
I think they also noticed my AFR heads, on the passenger side you can see the logo clearly...
They were all looking and pointing.
Might have had something to do with it. :emotions33:
johnsonwillie199
