2022 Z71 Suburban 6.2L bent lifters
AmazinglySmooth
Seems the bent lifter issue is still happening. My 2022 Z71 with 2300 miles got towed off to the dealer today since it lost power and had tons of errors/alarms. I just heard from the dealer that the lifters are bent. I waited specifically for a 2022 because of this issue, but it happened. They are also not offering the same as is mentioned here: GM Authority Link
A
AmazinglySmooth
They are only replacing one side per approval from GM. Cam shaft inspection says it is ok. Not very pleased after dumping so much cash on this vehicle.
sanman28
Stuff happens. They are making it right, it sounds like.
sanman28
What sort of head in the sand horseshit is this?
It’s the best scenario you can hope for. The truck is damaged and none of your bravado will change that. Best to realize these things happen from time to time and just make sure they fix it. Sell the truck after if you are butt hurt.
Banks22
Michigan
Wow that’s bull they only replace one side, idk a lot about engines and mechanics but a $70k vehicle, I’d be pissed
Polo08816
I thought this issue was resolved? Maybe there's some validity to the Consumer Reports rating... Should have been an easy fix.
mightymouse
Curious. Did you own a model from the previous generation? If so, did you notice more engine noise with your '22? I own a '17 and '22; the engine in my 22 seems to be louder and produce more noise. This is concerning as there may be a solid chance I will be joining the failed lifter club with a '22 at some point. I'm hoping this isn't the case, but the engine noise gives me doubt.
TrueAt1stLight
Minneapolis
@AmazinglySmooth I LOL’ed at your username. I’m mortified to hear this is happening to the 22’s. It would be curious to see if there’s any chance that engine is actually somehow from the 21’ builds or with 21’ parts as correct me if I’m wrong but didn’t the 22’s start production right around the timeframe of your build? It’s all moot as 21 and 22 are the same physical year in this case. Guessing this is obvious your dash is fully digital, right?
A
AmazinglySmooth
Dash is fully digital (see video for full details).
A
AmazinglySmooth
I have an '18 5.3L, but I got the 6.2L with cat back exhaust in my '22 so there is no comparison.
Fireman591
Michigan
The 5.3 and 6.2 engines are the same as the 2021 engines. Major design flaw increased with the DFM system that can bend a push rod due to a clearance issue at the base of the push rod and lifter sidewall seat. It is not a matter of if it is a matter of when with this design flaw. Super excited to get our diesel suburban this spring and say bye bye to our current 5.3 nightmare.
CrackerJack135
