Tonyrodz's Tahoe Build Thread
You asking about snow fall potential or spooning potential?:cool:
Hey now...
Swapped out the maf sensor with a used oem. I was hopeful, but no difference. Still sounds like it's kind of popping out of the exhaust. Still no cel. I didn't have time to look at the plugs. I also swapped out my idler arm, and idler arm bracket in my van. Not enough time in the day.....
Have you looked at live misfire data with your Tech2? I keep wondering if it’s just a burned plug wire.
97YukonNZ
Not a coil?
I don’t think you were looking at it right. It resets every 100 cycles. Plus I have never seen an engine run 100 cycles with zero misfires.
So misfires would somewhat be common? If that's the case how would you know it's an issue/problem?
Because most cylinders will have 2,3, 4 whatever and one or more will have 20, 30 100 whatever. There’s thousands of fires in a cycle of 100. When I had a burned plug wire I think I was getting like 100 or more per 100 cycles iirc. It will be obvious.
Ah ok, gotcha. I'm really hoping I can get to it on my next day off. I can feel that the power is off. I really thought it would've been the o2 or the maf.
You have to have a lot of misfires or it would be running good.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Hey tone looks like it changed to rain your way already?
Mckennahc
