????????2/3 2/4??????
JDTAHOE2001
HOUSTON
iI INSTALLED 2/3 2/4 DROP KIT ON MY 01 TAHOE. ITS SLIGHTLY RAKED. HOW DO I GET THAT EXTRA INCH OR WHAT DO I HAVE TO DO. THANKS FOR ANY INFO.
blueflamed03
Oklahoma
so it's a 2/3? What kit, and what all did you replace?
Chances are, you need to address the OEM shocks if you still are using them.
Do you have shock relocators?
Autoride?
J
JDTAHOE2001
HOUSTON
Djm with shock, w/relocaters, no autoride. I need shocks, i was thinking some nitro drop 2, but not sure
---------- Post added at 05:33 PM ---------- Previous post was at 05:29 PM ----------
Torsion keys, coils, and shock extenders. 2/3 djm
blueflamed03
Oklahoma
Jose, happened to me man, get rid of the shocks. They are holding you up an extra inch at least.
I took mine off and added the Bilstein shocks, but the Belltech (good ones) will do the job. You'll see the truck actually fall when you take one shock off...amazed me they held it up. But there is your reasoning.
Good luck man!
Narco
Atlanta
me three. replace your rear oem shocks and it'll def drop lower. you can also remove the isolators (black rubber inserts at the top of your springs) to get a little lower still.
AdrienR
