My 2003 Yukon build
corvette744
2004 Z-71
Northern illinois
Brake upgrade. Wilwood 16" big brake kit with 6 piston calipers. I also got the parts for the hydro boost conversion. Installing the brakes is pretty straight forward. They tell you to put Loctite 271 on the bolts, which would have been nice to include in the kit, since it's something needed. No big deal, I got a bottle at the auto parts store. You will need a torque wrench and 40 Torx bit. Everything else is just regular wrenches and sockets
The difference in size to the stock rotors is staggering
Only parts missing right now are the brake lines and the brake fluid, then I can finish the brakes up.
Thats beautiful i dont think i want to see the price tag for all that.Probably half the cost of the vehicle.
F
franky996
Austin Texas
It's pricey, for sure. But good brakes are a safety item that can safe your life. Besides, the truck is paid for. I can get a new truck, make payments etc or put some money in this one and build it the way I like it . Plus, I like the look of that body style better than the newer ones.
F
franky996
Austin Texas
Some more work done lately. Eibach sway bars and did the hydro boost conversion. Hoping to finish it all up this weekend. A couple of more small things then, fluids
F
franky996
Austin Texas
I know, but wasn't thinking about that at the time. I might replace the seat with a sport seat in the future. Something more side support and less weight
I used get tunnel vision too sometimes, focused on just the task I wanted to complete and not thinking. Then afterwards I looked back and go “ I could have made that a lot easier on myself”. I’m getting better at thinking things through the older I get and the worse my back is. Just looking at that pic made my back hurt. :mad:
F
franky996
Austin Texas
Relocated the oil pressure sensor from the back of the engine to the side of the oil pan where the oil filter is. That way I don't have to remove the intake manifold if I have to change the sensor again. The 2 foot harness extension makes it a simple plug in deal
F
franky996
Austin Texas
I also installed an oil catch can while I had the intake off
It separates the oil from the air and then reroutes the air back into the intake. At the bottom of the catch can is a drain
After I had done the electric fan conversion I noticed the voltage being a little lower than I was comfortable with at idle. So I ordered a 250 amp alternator and installed that one and now it shows 14+ Volts at idle with the fans running
Last on the list was bleeding the newly installed brakes
You don’t need to remove the intake manifold to replace the sensor. Just reach up on top and do it by feel. I’ve done it, it’s not that hard. That’s a nice little adapter though. ICT Billet makes quality stuff.
F
franky996
Austin Texas
So the dyno day didn't go as planned. Driveshaft blew up on the dyno at about 5400 rpm and 96mph . It was quite the bang when it let go. It also took out the tail shaft housing. Now I'm going with a 2 piece shaft. My dyno guy told me he had never had one blow apart on the dyno, he said they usually come apart on the road at about 142+mph. The 2 piece shaft will cure this problem
tRidiot
Please tell us you were filming when that driveshaft cratered!
F
franky996
Austin Texas
Unfortunately I didn't record a video of that. He was slowly making his way up the revs, each run a bit more, then looking at the data on the laptop. This happened at 5400rpm , later on the full run will be to the redline at 7000rpm
Here is a video of the damage underneath (no audio)
Damage could've been so much worse.
tRidiot
Man I wish I could do this kind of build on my Tahoe. Such a thing of beauty. Strong work, brother.
Kjg238
