New owner, driving on sand AWD questions
I finally found a lower mile family hauler but didn't quite do all my research..2006 Yukon XL Denali. Plan is to use it for camping and beach trips. After realizing this doesn't have a "true" 4wd system I'm starting to wonder if this will work or leave me stuck in the sand. For those of you who have had both systems is the AWD still decent? Plan is to put on 285/70/17 tires and finish off my front lift. So far did the Moog HD coils and KYB monomax shocks as the air ride had issues.
Thanks for and suggestions
If you do a search on here, a few years ago, a fella joined the forum here with an AWD Denali and he goes overlanding regularly with it. He said that to go where the 4x4s go, you have to drive it a bit differently. Mainly, keep it moving, slow and steady as Dan mentioned.
In 2013, TFL Truck road tested a 2013 Sierra Denali with AWD. While they complained about the AWD drive system, it went everywhere asked without getting stuck.
SRQYukon
Sarasota, FL
As others have said, wheel spin is the enemy. My father-in-law grew up in the 50s driving two-wheel jalopies on Florida beaches (before FL was overcrowded with condos, obviously). He taught me how to drive on sand. We did all of the aforementioned things to stay atop the sand. Here's another tip that works: If you bog down in the sand in spite of your best efforts, and forward movement ceases, try backing up while staying in your own tire ruts. These areas are already compacted by the weight of your vehicle. Go back about a vehicle length or two and then try moving forward again and steer out of your ruts and around the area where you began to bog down. If you can't avoid the same track, then you need the backup, get out and fill the rut with a shovel and tamp it before attempting forward movement. The key is to be patient and not get so bogged that the truck can't pull itself in either direction (or so deep the suspension starts to drag). I've never owned a 4x4 or AWD truck, but this technique works many times. We used to drive around 4x4s buried to the frame because the drivers would try to power their way out. It NEVER works. You have to finesse your way out.
06XLDenali
Mission accomplished!
06XLDenali
Awesome, where's that?
Assateague island, Maryland side. I drove about 10-15 miles to the VA border. It rained yesterday but still played it safe and aired down to 20psi. Piece of cake.
Drewphil
