Speed Engineering 3" Dual Exhaust Kit
Boosted Hoe
Speed Engineering makes a nice Stainless Steel 3" Dual Exhaust kit for GM Trucks. Have any of you tried using it on your Tahoe? The only real question is will the over the axle pipes fit with the coil spring suspension vs the leaf springs that the trucks use.
Mudsport96
40.923,-89.488. Illinois
Dual 3s seems overkill unless you have a blown 6.0.
Seriously, my friends Lightning making 510hp and 650tq is running dual 3s...
Edit: just read the other thread... should work good, carry on.
mikeyss
Longmont, Colorado.
I'm running 3" true duals on my 6.2, also my 6.0 in my 06 Sierra Denali has 3" true duals from factory to the muffler. If you are running a 6.0 or above, you need 3" duals
Boosted Hoe
Boosted Hoe
I will be running a Supercharged 6.1 .
Mudsport96
Yeah, that was the edit i did. Lol read that thread after replying to this one.
It wil still be plenty of flow for your setup. Believe it or not, the Lightning i posted about the owner went from long tubes and dual 2.5s with dual mufflers to 3 inch dual pipes through a magnaflow dual in/out internal Xpipe muffler and gained 10 hp and tq was basically the same.
I am not convinced it was the pipe size that was responsible for power increases more so the muffler design. But to each his own
Boosted Hoe
Boosted Hoe
I'm just wondering if the over the axle portion will work with the Tahoe rear suspension vs the leaf spring suspension on the Pick-up Truck it's designed for. I asked Speed Engineering, and they wouldn't commit, and don't offer a Tahoe / Suburban specific kit.
Mudsport96
I cant help there. I would guess it may be close, but with it being developed for leaf springs vs coils and control arms it may be off by an in or a mile.
You could always use what works and have the rest fabbed at a shop. That's probably what i would do anyway, as ive never been a fan of the duals on one side of a vehicle. But that's just me.
TiGrayMSM
