treehan77
TYF Fiend
Moog self lube bushing for me no problems so far 2 or 3 years. Stock suspension though.
Wish I would just do mine since it’s so cheap, but the little bolts that hold them on might disintegrate.Moog self lube bushing for me no problems so far 2 or 3 years. Stock suspension though.
Forgot to add this---this was while I was in park--Put the Tech 2 on, but couldn't really find much. I found a bunch of 4wd/transfer case stored codes in the history, and while looking the reduced engine power popped up 2-3 times. I couldn't reset it using the Tech 2 so I had to use my regular scanner for that. I looked all around, even in special functions and found nothing. I was able to cycle the abs.module on/off quite a few times--so maybe that rules out that module. So, nothing new to report.
Not sure if it helps but a long time ago I had a single abs light on for a sensor code, I replaced just the sensors and was still there. Replacing the wheel bearings solved the issue.Forgot to add this---this was while I was in park--View attachment 351932
This is what my regular scanner says it is. I was having an issue with the abs giving me intermittent issues prior, saying it was the left front sensor. I did the front pads maybe a month ago, and swapped in a new sensor. Now it's been lit ever since. I haven't had time to swap it around--i saved the old one.View attachment 351930View attachment 351931
Btw--that left front sensor is brand new, so that's weird.
You replaced the hubs?Not sure if it helps but a long time ago I had a single abs light on for a sensor code, I replaced just the sensors and was still there. Replacing the wheel bearings solved the issue.
The air I'm hearing sounds normal to me. Does anyone think it's excessive?
Thx for checking it out. I thought it was normal.I just went to the garage and did the same test (key out, engine off) and it was the same as your video.
With help of a mechanic friend yes he called that problem out on the spot and it worked. Timkins have been fine ever sinceYou replaced the hubs?
Spent 20 minutes cleaning throttle body and emptying can of sea foam in for a heak soak.Put the other can in gas tank.Next oil change i will run it threw the engine oil before i change it.Definitely smoother idle than i had.
What's heat soak?? I poured some seafoam in the gas tank just for good measure.How did you get it in for the heat soak? Pour it through the throttle body?
