Stiffer front springs/shocks on autoride ??
Slow5.0
Missouri
I just did 2/4 NorcalSS with belltech 2" drop spindles and belltech rear springs and also Wilwood BBK, even before these mods on heavy breaking front end will dip so much and rear will raise, off road display would shows that rear tires were loosing traction. So what can be done to make front end not to dip.so much, stiffer fron springs or stiffer shocks, i know there isnt any stiffer magnetic shocks, unless i ditch them.
Btw my 2016 Denali have only 40k miles, and my 07 Tahoe LTZ was much stiffer up front even with 115k miles
STORMIN08
other than what you mentioned...the addition of an adjust proportioning valve would be the other item that could aid in nose dive. not sure how your abs would react.
depending on your desire for ride quality, an adjustable shock or replacement coil over with dampening control would be ideal. you could adjust how much valving on the bump side and control nose dive
Slow5.0
Slow5.0
Missouri
Where would i get those shocks or coilovers ? Also how rear magna ride shocks would work if i delete front ones ?
STORMIN08
they offer a resistor that plugs in and fools the system. if truly an air ride assisted...you could always do a 1" drop coil, then adjust the sensor rod to allow a slightly higher PSI into the shock.
Slow5.0
Slow5.0
Missouri
I need this for front, rear shocks are with airbags on them .i never drove any 07+ GM suv without magnetic shocks. Are one without it that bad, before 16 Denali i had 07 Tahoe LTZ with air ride and magnetic shocks so i dont know how SLE/SLT Yukon or LT/LS Tahoe rides
STORMIN08
your front should have the air assist also...my 2012 was auto was both...and it also had sensor rods that i made adjustable.
Slow5.0
Slow5.0
Missouri
How about Belltech 16002 Coilovers Compression & Rebound Adjustable
Anyone tried these
Slow5.0
Slow5.0
Missouri
I dont think front shocks are with airbags, they have level sensor but they are there so auto ride and magnetic ride works as system.
I have never heard of air assist on the front of these trucks.
The front shocks/struts have an electrical connection on the top of them, if the suspension is a Z55 or Z95 RPO code. This electrical component of these suspensions operates independently of the air assist in the rear (though they are both hooked up to the same controller module).
RThomasII
Anyone tried these
I hate to bring up such a touchy subject but Tony (AKA NorcalSS) ran those on the 2016 Esky he used to own (its since been sold). If you can get Tony to respond he might give you some decent feedback on his experience with the coilovers.
Also check the "Show off your 2015-2016 lowered tahoes and yukons" thread. Start at the end and work backwards. I'm 99% sure there is a member with a suburban/yukon xl with 2" drop spindles and 16002 coilovers. The way his drop turned out makes me want to go to a set of 16002's but I'm still trying to decide on the Mag-Ride delete.
Slow5.0
Slow5.0
Missouri
I went twice over 39 pages and couldnt find anyone using those Belltech adjustable coilovers or im blid. Looks like they all talkin about 6" drops with 26" wheels
RThomasII
Page 38. Try reaching out to Eddie Rivera.
Slow5.0
Slow5.0
Missouri
He just responded. Those are Belltech adjustable struts 25004 not coilovers 16002 i was hoping
Yizzo88
