2018 Tahoe premier flowmaster 40 exhaust
Thanks for posting those videos.
Found the XS1259 For $58
Just curious why are most of you guys never recommending flowmaster, is it just over priced branding ?
Likely because of the way they sound! Granted, Flowmaster makes other model series that aren't the chambered design. But, for a vehicle with a full-length passenger cabin, a chambered muffler of almost any brand just isn't ideal unless you're wanting all-out noise, like a "squatter"/"tooter"/"fukboi". You can get away with a lot more with a truck since you have two walls separating you from the noise. But not so much with a car and certainly not an SUV. You have all that floor and cabin space for the sound frequencies to permeate and resonate. It's like you're driving inside a ported sub box. Oh, and the popular brand names are gonna be higher because they can. Some people just want a Flowmaster and couldn't care less how much it costs or how it sounds. There are Flowmaster knock-offs that perform exactly the same at a fraction of the price. They're all great for classic muscle cars that are primarily weekend toys because that sound is befitting. For a more refined family hauler, not so much.
Ghost10
Ghost10
Here's a video
Cold start
Yes I have thought about it last night and this morning and due to the giant body basting like a box with a chambared exhaust your just going to get fat bass from the exhaust
Anyways listen with headphones or surround sound to hear how deep this exhaust really is
Ghost10
Ghost10
Alright so this is the plan and hopefully it works out to my advantage
I'll swap the super 40 for the XS1259 And removing the reso in the back and have them run pipe to side where the rear passenger wheel is and add a Corsa dual tip :)
So I really don't know much about exhaust as you can tell but doesn't modified exhaust give you more gain or is it really just for sound ?I feel as if the super 40 has killed some of my HP from 0-50 but maybe it's just me lol
Will there be any gains or losses going with the I assume "glass pack" 1259 muffler ?
Really, any difference it'd make likely won't be felt. But, to specify the difference, it would be a loss in the low end, if anything. The Flowmaster is less restrictive than the stock muffler. But, with the baffles and chambers, the FM is more restrictive than the straight-through style. The FM is more about sound than air flow manipulation. No, it's not a "backpressure" thing. Not exactly. It's a flow thing. The factory exhaust is tuned to evacuate the exhaust gasses from the cylinders in addition to attenuating the sound through absorption and reflection. Some performance is sacrificed in meeting specified sound parameters.
Picture this: An engine is an air pump. At high RPM and more open throttle, it's trying to suck air in and get it out ASAP. A high-flow exhaust complements this because it supports the movement of a larger volume of air. At lower RPM and much lesser-opened throttle, there're not as much air moving through it nor is it moving as fast. That wide open, high-flowing exhaust pipe lets the air stall because it's too "roomy". The air can fill it more easily rather than being crammed into it. So the air expands all comfortable like, kicks back and chills, enjoying its casual Sunday drive through the exhaust system. It's not moving well enough to help evacuate the cylinders. Another aspect is temperature. Cooler air is more compact. This is why the front half of the exhaust system is 2.75" and the piping after the muffler is 2.5". Since the air has cooled that far down the line and after going through the muffler, it has compacted a little and, therefore, doesn't need quite as much room. The smaller pipe helps to keep up the speed, even though it is less volume, which complements the smaller volume of the cooler air.
I think that the large, but straight-through muffler makes up for the performance sacrifices the engineers made when they designed the stock muffler for its sound manipulating. But, it's not as ineffective at muffling the exhaust as the Blowmaster. Keep the 2.75" going into the XS1259 and the 2.5" leaving it. Since the XS is about 6" shorter than the stock muffler, a length of pipe will be necessary. I used a length of 3" pipe, cut a thin wedge out of it lengthwise (about 1.5" wide at one end and very narrow at the other), then squeezed that wedge-shaped gap together and welded it. This made a 6" long tube that tapered from 3" down to 2.5" to transition from the muffler's output to the rest of the factory pipe.
I moved my exit from the side to the rear. I'll be moving it back to the side.
Ghost10
Ghost10
Ordered from Amazon, now just looking for a decent tip for the back end, I’m going to have the res removed when this gets installed
The corsa tip that I wanted is not worth the $180
I do a lot of driving for work. When I was collecting the parts for my exhaust, I'd check out other car's tips and take note, sometimes snap a quick pic. I liked the tips on a particular model of Saturn Outlook, so I went to my local salvage yard and chopped the left and right side tips off of one. They're considered "trim" pieces, and sold by size, so I got nice quality stainless OEM tips for $4 or $5 each.
Ghost10
Ghost10
Btw love your romantic moonlight mow session ahahaha
Ghost10
Ghost10
I ordered a range tech RA003b
I wanted one of these for my 2010 Yukon but never bothered because the truck was needing too much work.
Can’t wait to see what this truck feels like in full v8 mode NOT having to run it in 5gear all the time which honestly I don’t feel the pep like you do when just going manual
Plato442
40’s have THE worst cab drone. Put a dual in dual out on my 03 Denali w/headers, cam, etc and it’s been absolutely garbage. Bumping up to a Flowmaster big block dual in dual out as soon as I can make the modifications to weld them in
GDEG
Good morning, first off I hope I am placing this in the right area. I purchased a 2018 Tahoe premier last year finally got around to at least dropping the stock muffler and welding on a flowmaster 40 series with flapper removed and stock resonator still inline it sounds good BUT a lot of low end bass from the exhaust inside the cabin which I am starting to not like.
My 2018 Denali has a dealer installed Borla exhaust system when I bought it. It apparently is not cheap to get a good sounding aftermarket performance exhaust. It is extremely muted. I would just reinstall a regular muffler and take the hit.
I'd have to disagree. My muffler was $33 and it had a great sound- volume and note, with no drone. It definitely wasn't the noise a Blowmaster makes.
Plato442
I put a flowmaster hushpower 2 on my 05 Sierra and it has great sound, and no drone at all. So I ended ups scoring another on eBay for $50…just waiting to install on something in the future.
Ghost10
Ghost10
Just had the flowmaster 40 removed and the XS12 added but did not have the resonator deleted yet need to wait to get more money
It’s so quiet but I’m sure once I get the res out of line and a pipe with tip it’ll be louder?
Ghost10
Ghost10
Also if anyone has a recommendation on a tip similar to the Corsa dual tip
Drewphil
