08 Tahoe help!! Cylinder #1 misfire
Isaiah13
I have a 08 Tahoe with 157k miles on it. The engine light came on, I had it scanned and it showed cylinder #1 misfire. I just replaced all the plugs and wires about 2 months ago, so I thought maybe it was the coil, I took the coil off cylinder #1 and swapped it with #3 coil to see if the actual coil was bad. The engine light went off and was fine until I drove home from work today and it came back on. Scanned it and reads cylinder miss fire #1, so it’s not
The coil I don’t think.
The Tahoe is running good other than a slight miss when idling but nothing real noticeable and the rpm hand is bouncing up and down slightly at idle. I haven’t tired replacing the injector yet, and I haven’t done a compression test on #1 cylinder yet. I know it could be multiple things like a stuck lifter and what not . I was just wondering if anyone has
had this problem and could point me in the right direction. Thanks!
GMT800 2005 Tahoe Z71
Navy Supporting Member
Start with a compression and compare #1 and #3. Check for vacuum leaks. You said you replaced plugs and wires, did you pull the plug to inspect? Did you check to be sure the plug wire is "snapped on" correctly?
I
Isaiah13
I haven’t pulled the plug to inspect it yet, the plug wire is snapped on correctly. I’m going to start checking everything over really well tomorrow. Hoping for a simple fix.
easymoney
I would replace that plug to start with. Its cheap. Just because you put a new plug in there doesnt mean its not defective. If you have the old wire maybe put that wire back on at some point if you continue to have issues
madmanjustice
i had the same thing on my PPV. I swapped the 1 and 3 coils and still had the misfire on number 1. So i swapped the plugs and wires on 1 and 3 and the misfire moved to number 3. I went ahead and replaced all the plugs and wires and cured the misfire until I totaled the PPV.
RED TAHOE LS
Rossville, Georgia USA
Take one of your wires and exchange # 1 plug wire
I
Isaiah13
I appreciate it, I will try to swapping the plug and plug wire and see if misfire follows.
I
Isaiah13
I checked today to make sure I didn’t have a stuck lifter, checked compression it was all good. The #1 plug was the problem. Replaced it running fine now, engine light gone.
I guess I will ask just one more time, whose makes the plugs? Also, while I am at it, whose makes the plug wires? Compression readings compared between #1 and #3?
I promise, last time I ask these questions and then I just give up and will stop bothering you.
Ossipeelake
