Anyone install exhaust manifold clamps to help broken studs? ***Updated***
Scrapman
A friend of mine has a Chevy truck with a 5.3 and developed an exhaust leak from broken exhaust studs. Of course, this made me want to check the studs on my 07 Tahoe. I do not have an exhaust leak yet, but the heads of the rear most studs (closest to the tail pipe) on both the passenger and the driver side exhaust manifolds have broken off.
I bought some of the Kral (KAP) clamps that bolt into existing holes on the head and clamp the exhaust manifold down where the stud is broken thinking that I am going to save myself a huge repair extracting the studs from the head.
On the driver's side, the clamp uses the bolt that holds the engine ground strap and also another hole on the back of the head.
Has anyone here ever installed these on a 07-14 Tahoe/Yukon/Escalade??? For the life of me, I can not get a socket on the driver's side ground strap. There just doesn't seem to be enough room. I tried from the top and bottom. The ground strap is crimped close to the hole that the bolt fastens it to the head goes through; so it seems to need a socket instead of a wrench. The wrench will not slip over the bolt head because of the crimped part of the ground strap.
Has anyone had better luck? I could use some pointers.
Thanks
There are a number of threads on this topic in the Forum, and many folks have successfully used these clamps. If remember correctly, Dorman also makes these clamps.
Other folks on the Forum with direct experience with these clamps will chime in.
S
Scrapman
Thanks. Although I am new to this site, I did try the search function before posting this thread and had no luck.
I found some pretty good information through Google, in threads that were also from this site. I don't know why they didn't show up in the searches I did here?!?
Here is one I am reading now that is pretty in depth.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Thanks. Hopefully you are on the right track.
The search function on this Forum leaves a lot to be desired. Many folks like yourself have better luck with performing a Google search with the key word 'tahoeyukonforum' added to whatever your primary search keywords are.
Glisella
NY, Westchester/Putnam border.
Hope this helps you guys...it's been a few years and the Kral clamps are still there going strong. I've actually had replacement manifolds, gaskets and bolts in garage for over 2 years but haven't done them yet since the clamps eliminated the noise. Not the right answer, I know but other priorities come first.
If link doesn't work search for "manifold clamp" and my username below it.
oh05ext
Ohio
I had 2 broken bolts in the back of both cylinder heads on my 05 denali. I tried to use the one on the rear drivers side and it was too tight of a fit for me to do with the dorman clamp kit. All of mine broke above the cylinder head so I just took my time and pulled the manifolds loose and used vice grips to turn the broken bolts out. I got lucky. If your handy its not too bad of a job, taking my time was about 4hrs per side give of take between beers.
donjetman
3 yrs and 40k miles ago installed 3 APDTY brand clamps/bridges:
Exhaust Manifold clamp, back driver side – APDTY# 028218
Exhaust manifold clamps, frt driver side & back pass – APDTY#028253
jeremiahm
Way North CA
I had two broken on the front right of the motor. Was able to extract the second bolt, but the first (front of motor) I had to clamp. Been on for 10k miles and had to re-tighten once at about 2k. Hasn't made a peep since. I did replace all of the other exhaust bolts at the same time to hopefully prevent more breaks. I used the dorman clamp and header bolts.
Jeremiah
S
Scrapman
***UPDATE***
Finally got time to try to install both Kral clamps this morning. Passenger side took about 2 hours, Driver's side took about 2 1/2. Here is what I did.
Took passenger side wheel and inner fender off. Unbolted dipstick hold down and removed next to last spark plug wire. From there it was just a matter of taking my time to get the part over the dipstick and under the last spark plug wire. It took longer to remove the tire and inner fender well. I took off the screw for the tin cover over the exhaust manifold where the clamp went over the manifold. This allowed me to bend it back and get the bracket in place. After installing the bracket, I took a socket extension and hammered the tin cover back in place with the end of the extension over the bolt hole. This got the cover close enough that I could replace the small bolt that held it into the exhaust manifold.
I wasn't looking forward to trying the driver's side because I have heard to many horror stories.
Definitely the thing that helped me the most was unbolting the transmission mount and slowly jacking up the transmission(while watching for anything getting bent or crimped) I did not remove the tire or wheel well. After jacking up the transmission, I had just enough room to get a wrench on the nut that holds the engine ground and break it loose. I then went to the top and unscrewed it the rest of the way with my hand.
I installed the top bolt with the bracket from the top, and the bottom bracket bolt from the bottom. I had just enough room to get the bracket bolts tight from the bottom and the hold down bolt from the top.
I also relocated the ground strap to one of the many holes on the side of the head above the exhaust manifold.
Hopefully this is some cheap insurance and no more exhaust manifold bolts break!
Thank you for detailing your work. This will help other folks with a similar issue.
mmosh
Thanks
Had the driver side bolt head break off on my 2013.. bought the same part and Midas put in in for me.. worked great.. no struggles
Gustavo47
I put 4 Dorman clamps on my 04 Denali about 2 years ago. Purchased from Rock Auto for about $15 each. Did the firewall passenger side one similarly. On the drivers side firewall one I took the wheel off and sqeezed in that way then wd40'd the hole on the back side of the head and started the bolt by hand then finished with a ratcheting wrench. Next time I would consider taking the intake off to make it easier. I would also atempt to clean the crud produced by the leak off the block. Over time it started to leak again even after replacing the gaskets. I recently had the engine replaced after 312k and noticed a lot of carbon built up around the port. The mechanic said the clamps were a good way to go. ALSO...keep an eye on your upstream O2 sensor. I had a bank 1 lean code pop up some time after that I believe was caused by the offset from the exhaust leak. The sensor was fouled.
brice715
