Truck leans to one side
02escalade
New jersey
Having a issue with my truck 02 2 wd Escalade I’m not really sure what to look for .. anyway then suv is leaning to one side in the front and back .. I have 2 inch drop spindles adj keys blisten all around hotckins sway bars front and rear and a adj panhandle bar also eibach springs in rear with about 8 years and 40k miles on them and 24 rims .. I don’t know why it’s leaning it’s very Noticeable ..bad shocks ?? Anything to do with the keys ?? I noticed it a little after having a new differtial put in also on highway if I hit say a small pothole or anything it wobbles side to side .. any advice I would appreciate as I’m not very familiar with all this stuff Iv heard of the Chevy lean but I don’t think that’s the cause
91RS
GA
Pretty much all of those lean to the driver side.
Snowbound
Jim
Chicagoland (Lockport)
Shocks wouldn’t do that unless one side was too short. Shocks only control rebound and dampening.
Gonna have to measure stuff. Park on level ground and measure frame height between right and left, control arm, diff tube and body. Could be sagging body mounts on one side. My 02 doesn’t have a lean to it.
02escalade
02escalade
New jersey
Well the driver side sits higher the passenger side of the truck is still lowered at the same height when it was lowered what would cause the one side to raise up higher now ?? A and like I said there a lot of side to side motion
NathanJax
Vacation Nathan
Jax, Fl
It's called the chevy lean.
You can adjust your suspension to take care of it. Move the lower side keys up. Then they sell cup extensions in the rear for the springs (basically using them as a lift kit to make it level)
02escalade
02escalade
New jersey
So what does it all of a sudden just happened I’m just curious ?? So basically I’d be taken away the lowered stance then correct ?? If I raise the lower side up that’s the side that still the height When the truck was lowered with 2 inch drop spindles …and adj keys …. The side that is low is still the same height when the truck was lowered years ago …. So what would cause one side to raise up??? I understand the Chevy Lean part I’m just not understanding what would cause a side to raise up from being lowered ??
But he said his driver side is higher than the passenger side which is opposite of the Chevy lean.
NathanJax
Vacation Nathan
Jax, Fl
Didn't catch that... either way, can still use my method to fix it
02escalade
02escalade
New jersey
Yeah I figured that message would fix it I just can’t pinpoint why all of a sudden the driver side would go up not down so basically if I level it out I’m going to take away the drop aspect of the truck I’m baffled at why the Driver side would raise up front and back
Have you taken any side to side measurements yet? I'm curious as to what the issue is. Btw--where in NJ are you? I'm in NJ too.
That’s a good question. Have you put it on jack stands and inspected everything to see if something looks out of place like a spring not in its pocket? Maybe try that and if nothing looks wrong drop it down with the floor jack fast on the driver side to see if it settles. I can jack one side of mine at a time by finding the balance point on the frame to jack from, then if I drop the jack fast it settles good. Just a thought.
TollKeeper
Brighton, CO
I personally would start by jacking up the rear of the truck, with the jack under the pumpkin of the diff. After both wheels are in the air, look to see if they are equally spaced at the gap of the wheel to the wheel well. If both sides are about equal. Than you know the problem is in the front. If they arent equal, its in the rear.
Edit: This will at least get you started. Its possible its in the front and back.
02escalade
02escalade
New jersey
I’m try jacking it up this weekend amd take some measurements and really look around ..Besides the wobble I’ve been driving the truck almost a 1000 miles a week for work
02escalade
02escalade
New jersey
it’s the weirdest thing the driver side raised up ….. Passenger side is the height it’s supposed to be after it was lowered
02escalade
02escalade
New jersey
Well pretty tied up this weekend but took a quick measurement the driver side is sitting close to 3 inches higher
02escalade
02escalade
New jersey
So now I’m so confused maybe it is leaning to the passenger side But that’s a huge difference Does anybody know how I can find the stock height of an 02 Escalade 2 Wheel Dr ? Just curious because then I can deduct the drop spindles and keys to see what the lower height would be
02escalade
02escalade
New jersey
02escalade
02escalade
New jersey
Do those springs look normal ?? Look really compressed but they are eibach lowering springs I’ve been working crazy hours so I haven’t really been able to look but my buddy asked me to take a few pictures for him
Conedaddy
