Bounce after McGaughy's 2/3 Kit Installation
nv6425
Hey guys, it looks like this may have been covered in other threads, but I'm truly disappointed (enough to want to go back to stock height and cancel the order on my rims) in the ride quality of my 09 Tahoe after installing the 2/3 McGaughy's kit. It included spindles, rear coils and shock extenders. It looks awesome, but the bounce is pissing me off, especially at freeway speeds.
It seems like it's mostly the back that has the bounce and front seems to be fine. Do I need to replace my rear shocks to get the factory ride back? If so, can someone please make a recommendation for what shocks to buy?
Sorry to be a ****** about this, but I'm far beyond annoyed! Thanks in advance!
preston
Humble, TX
I had the same problem with my McG rear springs, ended up switching to some Spring Tech ones that were cheap but are considerably better, but I would like to get some Pedders rear springs when the budget allows. The front is deffinately not your problem since your on spindles. You might consider just switching out the rear springs to another brand of springs, I would recomend going with Pedders rear springs with all the good reviews they get.
N
nv6425
Thanks preston....so you think if I swap the springs, then I will be fine? Should I also be replacing the shocks?
jee123
i just did my shocks and they were shot to shit...your truck is newer but wouldnt hurt..i got bilstein hds..bilstein hd strut and belltech sp rear is a popular combo did you use shock extenders?
N
nv6425
Yes, I used the McGs shock extenders that came with the kit.
jee123
how many miles do you have on the hoe
---------- Post added at 10:27 PM ---------- Previous post was at 10:26 PM ----------
good shock would help for sure..
jee123
man sorry to hear that...get a few more inputs before deciding.. you have any pics?
Modded
That Guy
Pretty sure you were the guy I was texting right?
If so, then yeah I say just got the Pedders rear coils w/o isolators route.
N
nv6425
Modded, yes that was me.
I'm seriously contemplating going back to stock suspension. The truck looks good, but I don't want to have to worry about it. Thanks to all for your help and input, I'll let you know what I decide!
CKendrick
