Tonyrodz's Tahoe Build Thread
Yeah true.
Just worked out you're an hour later because of day light savings. Was wondering why it was 11.30 where you are. 4pm here. And I dont know if my weather widget is telling weather in my time or yours. :angry94:
I'd think probably in your time, since you're the one checking it out.
Anyone know what this is worth? Cobra CBS. Comes with an extra mic, used I think. 20200604_150616.jpg20200604_150634.jpg20200604_150618.jpgThx.
Finally did my front brakes.
I didn't get an after pic. I cleaned off the grease on the boots, and I installed the new abs sensor. Now I'm getting an abs code for the ps! I bedded in the new brakes. Stops amazing now! Now I just need to get motivated enough to swap out the ps abs sensor.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Finally did my front brakes. View attachment 345351
UGH! You pay for every inch on this thing.
I installed this awhile ago. Hooked it to a keyed pwr course. It lights up with key on, but it doesn't charge. Anyone have an idea why? Maybe the keyed source isn't putting out enough volts? Maybe??20210720_165759.jpg
97YukonNZ
I installed this awhile ago. Hooked it to a keyed pwr course. It lights up with key on, but it doesn't charge. Anyone have an idea why? Maybe the keyed source isn't putting out enough volts? Maybe??View attachment 345362
Could be how you've wired it. Might just be lights showing n that's all?
Thought about wiring to cig lighter power? Guess then it would be on all the time then thoo_O
Should only be 2 wires to connect it. I would think if it’s lit up it should be working. Maybe a bad charging cable?
Yup, only per and ground. Both hooked up. I've used different cables to rule that out. Cables are good.
That's why I wired it to keyed pwr. I didn't want it lit at night while it's parked. Sometimes it sits over a week without starting it. I know LEDs don't draw alot of pwr, but I still don't want it constantly on.
Just documenting my steering shaft replacements.
Did upper and lower shafts. Pain in the balls like everything else on this Hoe! Done--but to 90% correctness. Call it good for government work!
Pics to satisfy all you voyeurs!
Upper shaft. It's best to remove the gas pedal to get to the bolt.
20210723_141018.jpg20210723_150851.jpg20210723_150902.jpg20210723_163049.jpg20210723_140052.jpg
Check out the differences between the old oem design compared to the new design. OEM is on top. I separated the upper shaft into 2 pieces. SPLINES!!
New shafts together.
New lower shaft play from banging it--
Compared to the old shaft play--I didn't bang this one in place--
97YukonNZ
View attachment 345644View attachment 345645View attachment 345646View attachment 345647View attachment 345648
Nice work!
Looks pretty involved. Did you find any steering sensors on your journey?
97YukonNZ
Hey looking at the 1st clip,is that shaft supposed to roll over straight or is it okay to have a slight bend in it. Can you see that from the cab while turning the wheel?
yottybaby
