02 Z71 Skid Plate
02Z71Raven
A couple of years ago, I was working on my Tahoe and had removed my skid plates. Can't remember why, but I found that these rubber bushings for the plate were really deteriorated, so being the confident genius I am, I threw them away and said to myself "self, you can buy these later".
Jump forward to last week, I decide it's time to put the plates back on and now I have no idea where to get these rubber bushings.
Anybody got a lead on these or am I shopping for a new skid plate?
exp500
Try a quick search for GM Parts, you will find a few that you enter your vin to get part number. Post up results if you need more help.
02Z71Raven
02Z71Raven
Tried that for quite some time, no luck. I found several like mine but they don't clearly state that they're for my specific truck and the don't say what the bushing numbers are.
02Z71Raven
02Z71Raven
It covers the oil pan I believe. The bolts that go in those two larger holes on the left had large rubber bushings they set in to. Those are the ones I need.
02Z71Raven
02Z71Raven
My best guess is that 4 - 8 are what I need, but it's just not clear to me and I can't find the pn's for them.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Bushings are not serviceable, part of skid plate
02Z71Raven
02Z71Raven
Grrrr. Thanks for the info. I suspected that may be the case.
I've taken all the measurements and looked at a couple of ways to substitute with other options. It's really just a matter of getting it secured and having the rubber to allow it to flex if hit.
I'll post what I come up with here for anyone else who may run into this problem in the future.
02Z71Raven
02Z71Raven
Post the last 8 digits of your VIN and hopefully @915_Tahoe will see it and respond with part #'s. He would not be at work till tomorrow to see to try and help.
Did you try any salvage yards?
I was offline for a few days and didn't see your post. Thanks for pulling him in. Bad news, but at least it saved me from spending anymore time searching for them. I haven't seen any in the local yards I go to, but hadn't really been looking for used ones. I guess I am now if I cant come up with anything better.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I was thinking you could take some old style upper shock bushings and trim them and add washers as needed. They have a 3/8" hole in the center of them. Get the sharp knife ready and don't cut yourself.
02Z71Raven
02Z71Raven
Good idea. I was thinking along the same lines. Maybe just look through some different ones at the junkyard and see if I can find anything that fits or can be easily modified. Just need to get it bolted up well enough for it to stay on there. I found some on Amazon that may work also.
Oh, and I'm definitely going to cut myself. If I didn't have scars from working on cars, I wouldn't have nearly as many as I do.
If you want easy and new, you can get those bushings at auto parts stores in the HELP line or some other line they use. Inexpensive.
02Z71Raven
02Z71Raven
I ended up using these rubber isolators and they're very squishy. We'll see if they hold up against the elements but they definitely worked to get it reinstalled.
02Z71Raven
02Z71Raven
02Z71Raven
02Z71Raven
Side
02Z71Raven
02Z71Raven
Bottom
Ossipeelake
