Another lowering thread...
TollKeeper
Brighton, CO
I have been thru the lowering thread, and looked thru all the pics, and specs of what everyone is doing.. And I still am unsure.
First let me say, ride is EXTREMELY important. Currently, I think my Esky rides just a bit to stiff. I want it to ride like its on a cloud. I have a bad back (5 partially blown discs). I only want to lower it cause it is hard to get in and out of for me.
Because of the above facts, I am thinking a 1/2 or maybe a 2/3, leaning more to the 2/3 I think. I do plan on keeping my Z55 Autoride. I do tow occasionally, mostly just a enclosed trailer with a couple quads or snowmobiles. But I do rarely tow a car/truck/skidster on a flatbed. This is also my road trip vehicle, with my wife and (soon to be) 2 kids. So again, ride is very important.
I also do plan on keeping my Factory 17" wheels and stock 265/70R17 tires. I am not a fan of big rims little tires. Sidewall helps with the ride quality.
So same basic starting questions...
What is the FreeTravel mod? Is it something I need to do?
What are Keys?
Knowing what you have read above, what are the suggestions?
I know my front/rear Z55 shocks are needing replacement, as well as my compressor.
Edit: I do plan on keeping the Rear Air Suspension, but not necessarily the Z55. Have not made a decision on this yet.
TollKeeper
TollKeeper
Brighton, CO
Looks like the BellTech 759 set would work.. But I am hoping I can hear from forum members about the ride quality?
What are Keys?
I'm not the most versed on the GMT800 Escalade front setup as far as Autoride and ALC. I know some have air shocks in the front and rear while others just have them in the rear.
What I can say is that having a cloud-like ride while not being too soft and uncontrolled is a delicate balancing act. Shock valving controls the most as far as ride quality and there's a chance that yours are worn and the ESC is firming them up. You can unplug the wires from all four shocks and go for a short test drive, preferably on a straight road with no traffic, and see if it rides softer.
New OEM shocks might be all you need to get the relatively soft Cadillac ride quality. But, yours may be riding as well as it possibly can and it's just still too firm for you.
Adding lowering to the mix, you can drop the front 2" with spindles and not affect the ride quality or amount of suspension travel, which means your shocks won't be put 2" closer to bottoming out. I'd go this route unless I wanted to change the shocks.
For the rear, the only way to drop it is with coils. The 34324 coils in that Belltech #759 kit seem to get great reviews. But, as with anything of this nature, you have to feel them for yourself. They're supposedly a 4" drop, 3" with the spacers in. They may be more or less on your particular vehicle. After completing your drop installation, you'll have to disable the ALC and put some miles on the new springs to settle them as well as assess the ride quality. Once they've settled, you can replace the spacer with a taller one to lift it if it's too low. With keeping the stock shocks (to maintain the ALC and AutoRide), I wouldn't go any lower than a 3" drop, but 4" might be ok. At this point, you'll install links of the appropriate length on the ride height sensors then enable the ALC. Proper sensor adjustment is critical since it controls the ALC and AutoRide. It may sound more complicated than it really is and there are a few more details, but we can cover that once you're actually into it.
The Free Travel Mod is where you cut the rear bump stop bracket from the frame to allow more suspension travel. The rear axle is already about 3" from the bump stop. Lowering the rear 3" puts the axle right on the bump stop, causing a very firm ride. Performing the FTM returns almost 4" of travel so it's like it was never lowered.
I highly suggest a lower control arm relocator kit: The DJM RK2000 (https://djmsuspension.com/product/rk2000/). The problem is that the Belltech shock extenders don't fit with this kit. At least, last I knew. Sometimes they change the designs and it's not known until people install then report about them. If they do, in fact not work, you'd have to get the DJM extenders: The DJM SE2000 (https://djmsuspension.com/product/se2000/). The RK2000 kit also has the sway bar end links you'll need for the drop.
Keys are what braces the ends of the torsion bars (your front springs) to "key" them to a particular clocking. They are adjustable. You can adjust the ride height up or down simply by turning the adjuster bolt. But, you'll only get so much adjustment out of them before they're maxed out. Lowering keys ("drop keys") re-clock the torsion bars so that they start from an already "lowered" position compared to the stock keys and allow adjustment up or down from there. For a 2" front drop, I'd stick to spindles since there are other components involved that adjusting the torsion bars will affect.
If you decide to lose AutoRide, this opens you up to aftermarket shock options. It seems that the general consensus is that Bilstein is the best option for ride quality and control. The problem with aftermarket shocks and maintaining ALC is that you're limited to what Arnott offers. I have no personal experience with the ride quality of their air shocks.
You could delete AutoRide and ALC and use air bags in the rear coils for when you tow. IMO, this is a better option since you'll have much more control over the spring rate, loaded or not, and the air bag kit is half the cost of a new compressor. If you don't tow a lot, this might be more sensible for you.
I wanted to improve the ride quality of my Tahoe as well as lower it as well as maintain load capacity. I deleted AutoRide and installed Belltech Street Performance struts in the front. This improved the feel over my worn and stiff factory AutoRide struts. I can only assume they ride about as good OEM struts should ride based on what I've read. I had Belltech SP shocks for the rear, but the wrong ones and they were super firm. I threw in some slightly modified Bilstein 4600 series shocks I had from a Jeep XJ and they ride beautifully. For the load capacity aspect, I installed air bags (Air Lift 1000 series). I haven't towed a lot of weight. But, what I have towed has only required 10 psi or less in the bags (they max at 35) to keep the rear level and it has never felt overloaded, loose or uncontrolled. Since my lowering springs are considerably softer than stock (Jeep TJ coils), I keep about 5 psi in the bags to maintain a more stock-like ride quality. I can drain the bags and it'll ride a little more cushy, but I don't like the way it feels when turning at speed. All in all, I have my 3/4 drop with improved ride quality, handling and load carrying capability. My next trick is to see if I can use the factory compressor to control the rear as intended, but with the Air Lift bags since I don't/can't have the air shocks. That project has been on hold for a long time due to little necessity and much bigger obligations.
TollKeeper
TollKeeper
Brighton, CO
Lots of info there.. Thanks
My plan was to keep the ALC, but maybe lose the Z55 electronic shock. This would allow me to tow, and not worry about rear end sag.
This is just a highway cruiser, daily driver.
My current Z55 rear shocks are completely blown on the air bag, air compressor is INOP, and I believe since I have a "service suspension" light on, its likely making the front shocks ride stiff as well.
Will have to contemplate a course of action over the next couple months.
Was also hoping for more input from others that have lowered the GMT800, and experiences there in.
Just to give you an idea. I went with a 2/3" drop myself. 20210406_191118.jpg
I'm also running 265/70's on mine. I have Bilstein 4600's on all 4 corners, no air ride at all. It originally had the ZW7 Nivomat suspension. I used torsion keys to lower the front, along with lowering springs and shock relocation brackets in the rear. It rides ok, the rear bangs hitting a big bump or a deep impression in the road. I don't have the rear bump stop mode. If I had to do it again, I'd go with lowering spindles for the front. Overall I'm happy with the look and ride, but I also never tow with it. Imo it handles much better and sure footed. I also have front and rear Hellwig sway bars.
BTW--Much easier getting in and out of it too.
You can buy the Arnott shocks that have new air sleeves on them as well as a new compressor from Arnott or Dorman. This would give you your ALC and eliminate the rear AutoRide since the Arnott shocks have "dummy" resistors in them to make the system think they're connected to operating AutoRide shocks. You could lower up to 3" and, with careful height sensor rod shortening, shock extenders and the free travel mod, run the ALC shocks. I wouldn't go more than 3" of rear drop on the ALC shocks, though. You could get new regular shocks for the front and use resistors (just like the Arnott shocks have) to spoof the system into playing nice.
I deleted Autoride front and rear and installed resistors at all four corners. No suspension system warning lights, ever.
Byoung1330
Cookeville tn
Here’s my 3/5. Mcgaughys spindles which are awesome. Belltech 5305 with half coil cut. Spohn Panhard Spohn upper an lower control arms. Did have bilstein shocks now have belltech sp. 3/4 ton purple keys. Rides pretty good.
TollKeeper
TollKeeper
Brighton, CO
I have seen a couple people saying that they could NOT run 17 inch wheels with the 2 inch spindle drop.
Can anyone confirm this?
I see that some of the spindles are stamped with a message saying "must use 17" or larger wheels", but I have found user reviews that say, and show pics, that they couldnt. Ball joint would not clear, even after shaving the bolt head off.
Byoung1330
Cookeville tn
They are still available an some the best. also I’m pretty sure my factory spare 17 won’t fit. Didn’t try shaving ball joint but I don’t think it would if I did
It'll vary from wheel to wheel. Hell, my neighbor had to shave his studs to fit the 18s he had.
TollKeeper
TollKeeper
Brighton, CO
Anyone able to confirm that the OEM rear shock 25871432 will work on my 2006 Esky?
They appear to be for a 2007-2014, but cant see any reason they wouldnt work on my 2006?
TollKeeper
TollKeeper
Brighton, CO
I think I might have answered my own question. Those are Z95 shocks, Magnaride. I need Z55 shocks..
I found a set local to me for cheap! But unless the Magnaride and Z55 are interchangeable, I will have to pass.
TollKeeper
TollKeeper
Brighton, CO
I am having a hard time finding the Z55 front shocks. Am I missing something..
Searched RA, AZ, AA, Amazon, eBay, and a few others.
Am I looking for 580-439? I have 17" wheels, and these say EXCEPT 20". But I cant find any other part number?
a1parrothead
