Steering Position Sensor Replacement
Multnomah Falls
Military
On my 2005 Z71 I just installed new wheels and tires and the wheels did not have the TPMS sensors on them and every time I start I get that message and I just clear it and it stays out till I do a restart.
In your case: sensor bad or a fault in the system. You have any codes or just the TPMS warning? If I remember right, your Tech 2 should be able to pinpoint. Others will chime in if I am wrong.
YukonRog
YukonRog
Grass Valley CA
Same wheels, same positions, no codes, just had battery disconnected while changing out the steering wheel position sensor.
YukonRog
YukonRog
Grass Valley CA
You made that look too easy! I wouldn't have thought to go the extra steps to completely remove the steering column. You're a pro for sure. So, look at these two sensors, the one o20210609_110154.jpgn the right is made in China and failed day two. The one on the left is made in Japan. (The one I installed today) So do you suppose the Chinese one was a counterfeit?
Super Moderator
Elev 5,280
You made that look too easy! I wouldn't have thought to go the extra steps to completely remove the steering column. You're a pro for sure. So, look at these two sensors, the one oView attachment 281477n the right is made in China and failed day two. The one on the left is made in Japan. (The one I installed today) So do you suppose the Chinese one was a counterfeit?
The one on the right is a Dorman.
Super Moderator
Elev 5,280
How can you tell? Made in China?
The Dorman icon, the flying V or whatever it's called. Not OE.
EDIT: some Dorman products are guaranteed for life, so you may want to see if you can get a refund.
Thekenstar
