Steering Position Sensor Replacement
YukonRog
Auburn, CA
Anyone have any advice, or tips on replacing one of these? I replaced this one once before but I also replaced the intermediate steering shaft. So I disconnected it from the engine bay side. I've watched a couple of videos and they go at it from inside the cabin. Tape the steering wheel straight and support it from cargo straps around the roof. Then loosen the dash a bit. I might add the last one failed in one day but it might have been a counterfeit or Dorman. Not genuine AC Delco.
ivin74
05 NBS Nali
Htown, Texas
I've done it twice and both times I have taken off the steering column to change it out.
If you do remove the steering column donot pull the pin until after you reinstall the column and the wheels are straight.
YukonRog
YukonRog
Auburn, CA
Thanks, last time I bungee'd the steering wheel straight. Think maybe that wasn't good enough. This time I plan on using the duct tape trick I saw on one of the videos. I know you need to leave the pin in until the last. But, how do you tell if the wheels and steering wheel are perfectly straight? How much forgiveness is there?
ivin74
05 NBS Nali
Htown, Texas
I'm not sure how much forgiveness there is but the first time I did. I did the best I could and it worked fine until the part gave away. The second time (2020) I zeroed out the degress using the Tech 2, taped the column made some marks on the intermediate and started the disassembly.
If you are off a bit the dealer can alight the steering to match the steering degrees. Basically they zero out the steering using the Tech2 and adjust the outer tie rods to have the required alightment.
YukonRog
YukonRog
Auburn, CA
Yeah but what does a dealer charge for that? My local dealer quoted me $500 just to scan it.
YukonRog
YukonRog
Auburn, CA
I just recently bought a Millennium 90 to kinda cover all my vehicles. I know it reads wheel speed sensors but I'll have to look at it again to see if it reads wheel centering. I know it says the Wheel Position Sensor is bad. But yeah, when you can buy the same tool the dealer uses for less...
YukonRog
YukonRog
Auburn, CA
Well I changed it today without too much trouble and I'm happy to say there are no warnings anymore. But, now it's not reading any tire pressures. Since I had the battery disconnected I wonder if they needed to be reset. So I went by the book, ignition on, cycled light switch 3 times until it honked twice, and started letting air out of the DS front tire for 10-15 seconds. Nothing. Is there a fuse that's out or something?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Recently replaced mine doing it the way @ivin74 described. Beer was involved too and seemed to make it go faster.
YukonRog
YukonRog
Auburn, CA
No beer involved for me on this today, it was before noon. Any advice on the TPMS not reading?
On my 2005 Z71 I just installed new wheels and tires and the wheels did not have the TPMS sensors on them and every time I start I get that message and I just clear it and it stays out till I do a restart.
In your case: sensor bad or a fault in the system. You have any codes or just the TPMS warning? If I remember right, your Tech 2 should be able to pinpoint. Others will chime in if I am wrong.
YukonRog
YukonRog
Auburn, CA
Same wheels, same positions, no codes, just had battery disconnected while changing out the steering wheel position sensor.
YukonRog
YukonRog
Auburn, CA
You made that look too easy! I wouldn't have thought to go the extra steps to completely remove the steering column. You're a pro for sure. So, look at these two sensors, the one o20210609_110154.jpgn the right is made in China and failed day two. The one on the left is made in Japan. (The one I installed today) So do you suppose the Chinese one was a counterfeit?
Moderator
People's Republic of Colorado
You made that look too easy! I wouldn't have thought to go the extra steps to completely remove the steering column. You're a pro for sure. So, look at these two sensors, the one oView attachment 281477n the right is made in China and failed day two. The one on the left is made in Japan. (The one I installed today) So do you suppose the Chinese one was a counterfeit?
The one on the right is a Dorman.
