2005 Tahoe Ls stalling
B
Bacon83
Regulator is in the tank. But I connected a fuel gauge to the rail and it never cuts out. Even after it died I have 54 psi at the rail
Sent from my SM-N975U using Tapatalk
TollKeeper
Brighton, CO
Next time it dies, open the fuel cap, count to five, put it back on, and see if it starts. This doesnt mean the regulator is working, but if the fuel tank is over pressurizing, then the return may not be able to return to the tank from tank pressure.
(wow, thats a tongue twister)
If you think the ECM might be getting heat soaked and causing the issue, get a can of computer air, remove the plastic cover on the ECM, turn the can upside-down and spray the ECM case in an attempt to cool it down.
B
Bacon83
I dont think it's the ecm at this point. I replaced it this morning and got the same result
PNWYukon
Olympia, WA
I don't know if this applies to your situation or not.
Maybe swap the coil packs out and see if that helps anything, if you are having consistent misfires listed on your scanner.
Pimpin
Kudos...I've been silently following and hoping you'd figure it out. I am glad for you and will try and remember that if I ever need it for either myself or to help someone else. Thanks for letting us know all that was done and thank you to those ideas everyone gave. Darn good advice...
B
Bacon83
Quick tip on finding that wire. Just follow the battery negative cable to the block. It's attached to the same bolt. About 6 inch behind the power steering pump
Byoung1330
Cookeville tn
Truck has about 280k on it. From a cold start it will run and drive for 20 minutes then stalls and won't restart. I've already changed the crank, cam, map, mass air, oil, and coolant sensors. Along with the fuel pump, fuel relay, ignition relay, and the ecm. Plus cleaned the throttle body. The truck has no check engine lights on. And at this point I'm completely lost. When it dies I have 54 psi at the rails. Throttle body is at 4% at idle and opens to 14% after it dies. Also showing pluse width on the injector. Any ideas please comment.
Actually had a buddy that had this happen. His issue was the new crank sensor he installed was a dud. Installed another an problem fixed
Logan5
Albany, NY
Truck stalled while driving today, luckily I got it into a park lot with momentum before I had to stop. Won't restart, no engine light. Nothing visibly wrong, cranks, won't start. Making some weird sounds like it half starts then immediately dies. Can't figure out so I call AAA. Waiting around for the tow and I start reading up. I find this thread. Ignition ground.... sounds easy to check. Crawl under the truck, find the ground, wiggle it with my finger and it pops right off.
Well then.
Grab my knife, strip a little wire, wrap it around the battery ground, zip tie it on, boom, starts right up. Drove it home, cancelled tow, did a proper repair of the wire, and all in time to make it to the bar for beers.
brice715
