Liftgate glass button replacement
Amaster
Laramie wyoming
I was wondering who you would go about replacing the liftgate glass button on a 2011 Yukon
Sent from my SM-S506DL using Tapatalk
wjburken
Eastern Iowa
The button can be popped out from the trim piece and then there is a short harness that you disconnect and then carefully, because there isn’t much slack, connect the harness to the new switch and pop it back into place. It’s a 10-15 minute job. There are two spring tabs that hold it in place. I’ve done it on 3 of these vehicles.
I did it in 3 minutes with a small pick or screwdriver!
Easy peasy man!
Drewphil
