Frustrated with needing tech 2
Amaster
Laramie wyoming
Okay service brake soon came on right after I bought my truckfrom a dodge dealership and I've heard the only way to get rid of the message is with a tech 2 scanner Googled it 249 bucks not bad then figured out Dorman programmers won't work for key fobs erg then I found out tech 2 needs a 10 year old computer to run it really im sorry our 06 Denali didn't give us a inch of trouble so this is pissing me off how much stuff is locked behind this pos
Sent from my SM-S506DL using Tapatalk
have you checked the brake fluid level?
if so....assuming it is full and there is no ABS light on
then unplug the brake fluid sensor and see if the service brake message goes away.
if so....then fluid level sensor is bad or funky, or proportioning valve is stuck.
most likely bad sensor if no abs light.
doesn't take a tech2 already did that myself and the tech2 will only tell you the brake fluid level is low yes/no, beyond that you have to do it hands on.
the only other issue would be if the abs light was on as well then there is air in the abs pump or abs pump is failing. in that case yes a tech2 or similar high end scanner would be needed.
A
Amaster
Laramie wyoming
How do you fix the proportion valve
well first you want to make sure it's not the brake fluid level sensor, some trucks do not even have one. if you unplug the sensor the service brake light will go out, then it's just a matter of trying another level sensor, if the new sensor does not work. then vvv
If you suspect the valve one way is to drive it around and do several hard fast stops (emergency stops) probably better to do it on gravel or dirt if possible and just do that random for a couple of days and it may straighten out on it's own, another way is to slow bleed the rear brakes. others have said they unjammed it at the valve and some say that it can't be done that way.
I would not try that unless there is no other choice, last option is to just replace it.
I jammed mine up once by changing the front brakes and then didn't slow pump the brake pedal and drove off and had to stop suddenly sending the pedal to the floor and it jammed the valve, i got it unjammed by doing as above, driving and doing some emergency stops and it fixed it's self after about 3 days.
...then I found out tech 2 needs a 10 year old computer to run it
Not so. If you need to program a module and desire to do it yourself, you can connect the Tech-2 to your modern computer with the appropriate adapter and either use the Tech-2 as a pass-thru device or download the software to the Tech-2 and transfer it to the vehicle.
A
Amaster
Laramie wyoming
Well I got one on the way anyhow decided there's a couple of things I need it for so
UpAndDown
Boston, MA (MetroWest)
How much was the Tech 2 and where did you buy it? Are there different versions? It seems Ike it might be a justifiable buy for owners of these trucks if it’s priced reasonably and gives true dealer level diagnostic and programming capabilities.
anything on the market should be current since software was last updated several years ago, chinacardiags has them.
What is the difference in all the ebay units?
These units are basically all the same. There can be differences in the accessories that are supplied with the unit (CANDi module, various connectors/adapters, etc.). Also, some are offered with a case to house the unit and all of the accessories, while some do not offer an included case.
TollKeeper
Brighton, CO
And Card Firmware Versions
RobertR
When it says it doesn't support trucks, does that mean it does not support Silverado, Tahoe and Suburban or HD Trucks?
Fubar0715
Scott
Southern New Hampshire
I think you should rent me yours for a day! :flowers2:LOL
CKendrick
