2 door side window rust.
warndogg
So a have a little rust spot going in the corner under the side glass. Has anyone had a similar experience or know the best way to fix it? I think water is getting trapped in the window gasket and causing rust.
The second picture is where I put some flowable silicone around the top of the window seal to try to keep moisture out it seemed to help for a little while.
I cant find anyone who wants to redo the window as they say they can't get the glass seal. Any suggestions are good.
Lerin
I have the same problem but way worse. Did you ever find a supplier for the seal?
veteran111
