The factory Nav SUCKS!
jdpromo33
Proud Tahoe Owner
Bloomfield, New Jersey
I'm so tired of the factory nav repeating the message "Please stay on the current road" like every 2 seconds.
Is this a fault with the system or does everybody's do the same thing?
I'm about ready to put in an aftermarket unit
dheadv8q
Oviedo FL
I travel with my Garmin on the dash. It may not be as flashy, but its a hell of a lot smarter...
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
Just go ahead and mail it over here :) I'll use it for you, I'l even update it to 2009.
It has to be better than the Mapquest App or Map App on my iPhone.
Seriously though, what software version are you running?
I have not heard this complaint before.
I wish I had the Ducats to buy it off you.
jdpromo33
jdpromo33
Proud Tahoe Owner
I updated the map disc that was on posted on here a little while back but not sure if this is a software glitch.
How can I update the software?
Eagle
EL PASO, TX
The map discs have teh software in them. It's automatic if it needs it.
Did you try simply turning off the voice prompts? According to the manual, you can do so when in audio mode
If you don't have a manual, go here
www.mygmlink.com
register by Year/model (2005 Tahoe was TNR IIRC) and you can download the Owner's manual for your nav. I'm reading it now.
(yes I do have the manual.pdf, the install .pdf and the nav Disc on my computer, but no NAV UNIT, LOL)
gtbigup01
Columbus, GA
I don't have that prob. Maybe you got the wrong update for your vehicle. 2009 might not be the update for ur truck, the update are vehicle specific. I'm still rocking an old version like a 3.1 or something like that and it get me places just fine
Eagle
EL PASO, TX
no, he has the right update. it is the most current version of the nav software. If it weren't it wouldn't run it as the new ones are Denso, not delphi.
"Voice Guide in All Mode: Touch the On screen button
to hear navigation voice prompts while in Audio mode.
You may also touch the Off screen button to turn off the
voice prompts."
thats on one of the pages of the "nav setup" screen.
jdpromo33
jdpromo33
Proud Tahoe Owner
voice prompts."
yeah your right I have the right software and will check it out today.
I'm actually gonna add the 6 CD slave unit in the truck today so will look at the nav set up while I do it
I'll let you know how it goes.
Cheers man
JD
Eagle
EL PASO, TX
n/p
you can also turn the volume of the voice prompts down to 0.
G/L
---------- Post added at 09:31 AM ---------- Previous post was at 09:26 AM ----------
one final thing i just thought of, make sure the "nav repeat" button isn't stuck.
it it is it will just repeat the last prompt annoyingly over and over again.
jdpromo33
jdpromo33
Proud Tahoe Owner
n/p
G/L
no I checked all that and it doesn't do it all the time. Just at certain times it was say, Stay on the current road and then every 10 seconds it pings and makes the same announcement
Bailey-Hoe!
Vermont
Maybe it hears you and thinks its in England. :)
OmarR
Indianapolis, IN
As you approach any "major" intersections, like an exit to another highway, highway splitting off into 2, etc, the NAV will inform you to stay on the current road.
Are you sure it's not just instructing you as you approach these major turn points?
jdpromo33
jdpromo33
Proud Tahoe Owner
No it does that also which I understand.
It's like when I'm on a road where there are no turns for 5 miles and no intersections and it keeps repeating the "Stay On The Current Road" message every 5 to 10 seconds. But again it doesn't do it all the time.
CKendrick
