Denali interior in Silverado
2006yukonDenali
Couple months ago I bought a Denali. I absolutely LOVE it. So much so, that I want to swap a Denali interior into my duramax. It's a 2006 lt (heated leather, center console, fully loaded), and I have the chance to buy a 2006 Denali XL parts truck. I was wondering if I would be able to swap the seats, door panels, dash, steering wheel, and everything from a Denali XL into the duramax without any problems. Like wiring harness, mounts, or anything like that. Thanks in advance.
I think much of it should be pretty straight forward swap. I would go to GMPartsDirect website and see if the part numbers of the items are the same for both vehicles.
adventurenali92
Big Bear Lake, ca
Everything will physically fit as long as it’s GMT800 platform to GMT800 platform. Seats all bolt in the same way, though I’m. It sure about the back seats as I have never seen how they bolt in in the trucks. If the have the same seat options( heat, movement adjustments) they will probably even have the same wiring harnesses. The dash and bezels and door panels should all fit just fine. If you’re moving the gauge cluster over, the correct mileage for the Silverado will need to be programmed into the Denali cluster. I can’t see what anything else wouldn’t move over.
2006yukonDenali
Awesome. One of the biggest reasons I want to do this is I want to put the captains chairs in the back. I think that's a really cool look
Mezzo
From my experience the Denali/Esky Center console won't be a direct swap with the wiring harness,it will plug in but the pin locations are completely different
S33k3r
Dallas, Texas
I've kind of wanted to do something similar in my Crew Cab, and install a console between them. Haven't tried it yet, though.
adventurenali92
Big Bear Lake, ca
I know that in the SUVs people have converted from bench seats to buckets and vice versa. But the seats always have to come out of a matching wheel base SUV. I would think that because the bucket seats in the Xl denali are quite large there might be a space issue in the pickup truck. And they may not match up to the bolt holes in the floor. But I’m not sure on that. Only way to know for sure is to get the seats into the truck and measure.
CKendrick
