Buy or Don't Buy
  • Total voters
    13
mdcaffee
I'm considering purchasing an 05 Yukon XL SLT with just over 145,000 miles. It has lived in the south all of its life and is in great shape cosmetically.
What should I keep an eye out for in the guts?
My understanding is the 5.3 V8 is stout and the transmission is pretty good too. So this may have a lot of life left in it. What do y'all think?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
Look for any exhaust manifold attaching bolts being broken, conditions of any fluid you can check, belts age and if the tensioners and idler are quiet, all dash controls work and rear a/c and heat works, brake feel and if you get pedal pulsations when doing a high speed slow down, leaking shocks, any maintenance and repair records you can get your hands on, steering wheel controls all working, electric rad fans working and no bearing noises, even tire wear and not cupped tread or uneven wear, steering wheel slop while driving, pull left or right, stops straight or pulls when braking, is brake fluid dark, do seat heaters work, leaks at front axles, leaks at front and rear diffs, leaks at trans and engine, age of tune components....etc.
Others here will chime in.
treehan77
TYF Fiend
Crestview, FL
Make sure oil is clean and not frothy/milky. Make sure oil pressure is good (around 40 psi idling), drive it for a good while at all kinds of speeds, make sure it is t running hot or low on coolant. Check condition of front suspension, 150k-200k they are usually worn. Ball joints, pitman, idler etc
Teamiez
How much are they asking if you don’t mind me asking and is it a 4x4? It does look beautiful from the pictures.
M
mdcaffee
Oh, make sure you can put gas in it, common problem trying to fuel it up. Can be expensive if you aren’t doing repairs yourself.
IF I understand right - when filling up it will have something occur that causes the gas pump to stop before the tank is full. Is that correct?
M
mdcaffee
The transmission is definitely not a solid part of the vehicle, if it was not replaced with a very good rebuild already put the bucks aside. 4L60E’s were meant to move camaros lol
I appreciate this feedback - I've read that as well after doing some more research. I'll be sure to ask about it. If the motor is strong I'm down to replace the transmission - but if the motor is going to fade... I might think differently.
My hope is to get 3-5 years and 50,000 miles at least - from what I've read and been told by others such as yourself - that's easy to do. The guy who owns this is a mechanic - he says they have kept up with maintenance because they enjoy even the simple fixes. I'll be driving it later today and will be checking what you and others have mentioned.
Welcome to the Forum from NH.
Nice looking truck!
treehan77
TYF Fiend
Crestview, FL
Yes, it will literally take you 45 minutes to fill the tank, cause you can just BARELY pull the pump handle and trickle it in, otherwise the pump will click off. It’s a problem with the EVAP system. It can be an easy fix, but can be more involved also. Mine was not real easy, and wouldve been relatively bog bucks if I had a shop fix it.
I got my 2005 several years ago with about 150k on it, it’s almost 200k now. Power train has been great, lots of little annoying issues, sensors, minor stuff really.
willinnashville
Nashville
If the price is right, score it! I love my 05 Denali. I bought mine in 2010 with 99k on it
That said, I had to get a trans rebuild at 175k and I've fought all the various evap system system issues, including the pellets from a worn out charcoal canister.
steve45
I've got a 2000 4x4 Suburban that has given me few problems (there, I just jinxed myself). In it's 286K miles, it has had a few sensors fail, the window lift mechanisms have broken, and the rear crankshaft seal has leaked badly.
Mine was totaled by the insurance company due to hail damage. I replaced the hood, and you can hardly see any damage.
I say buy it.
2591tdj
Miss
My 2005 Z71 Tahoe has been a great vehicle with very few problems and no major engine problems. Still on original front brakes at over 175,000 miles. Replaced A/C compressor, front diff (due to my own stupidity), shocks, blower motor resistor, blend door AND the vapor canister, purge valve, purge solenoid, gas cap, etc., all of which I replaced myself except for the condenser and front diff. Some of the dash panel lights are out out making the DIC hard to read. Headliner needs replacing as does a rear window regulator. I still drive it more than my 2019 Z71, especially when going off road or pulling my boat or utility trailer.
When filling the tank, don’t try to squeeze more gas in when the pump cuts off. Quit filling when it cuts off. Overfilling can lead to the EVAP system problem of taking forever to fill the tank and requiring replacement of the EVAP parts listed above.
M
mdcaffee
Update - the XL is mine!
Now contemplating a radio upgrade to get Apple Car Play & a backup camera. Let me know if you have any pointers. (I've found a few on youtube)
Congratulations on your purchase!
For the radio, lots of folks here like Kenwood and Pioneer, but you can't go wrong with Sony, Alpine and others. All of there radios have Apple Car Play. Go to the Crutchfield web site and check out the available radios with the features that you are looking for, and compare prices.
Some folks here have installed rear view cameras, and they will chime in with their suggestions.
wildcatgoal
Take it for at least 20-30 examples of slow acceleration through 2nd and 3rd gear. My transmission started getting confused only on light pedal acceleration at this time and then all of a sudden it started slipping in reverse and soon after would feel like it comes out of converter lock while cruising slight inclines on the highway. I have gotten quotes from a number of places who tell me they won't even bother trying servos and what not (which I already did to no avail) because it's a 4L60E and it needs a rebuild, end of discussion. Not the hardest transmission to rebuilt. Not the most expensive. But a reputable shop is going to charge me $2500 to do it (I have a 4x4) and the rear main seal. Every other shop I called wants $3K to $3500 and most will swap the transmission, not even rebuild it. The trans is the weak leak on these, unfortunately. If driven nicely and not relied on to tow all the time they'll go 200K but about that time they start to give up.
wildcatgoal
I have a Pioneer MVH-1400NEX. The only thing I don't like is the lack of a knob for volume, but otherwise it's got the Carplay and the backup camera option and I have an amp hooked up with some upgraded (although... oddly harsh for a silk dome tweeter) speakers. It doesn't have Android Auto, but I don't have an Android phone so I really don't give a shit about that.
jarydM
Lost in the Woods
Tennessee
Congratulations on the Yukon again! Glad you found the forum, even before my suggestion.
radio change and backup camera add isn’t bad. Did it in an afternoon. Hardest part was cheating it to bypass the park/drive lockout, and wiring it to automatically trigger the backup camera on shift into reverse
Denali_XL
Congrats! I have a 2005 Yukon XL Denali that I purchased used at around 150k miles. It did have the transmission rebuilt just before I got it. So I would just plan on that and set aside some $$. This is very typical and one of the weak points of these rigs. Also, just replaced the z55 autoride suspension which was $3k for OEM parts and installation. Yes, I could have went a cheaper route with aftermarket parts or frankensteined it with a conversion kit but I want to keep this for awhile and wanted everything back to as much stock as possible the way it was meant to be. And the exhaust system needed to be replaced which was about another $700. I went with a nice Magnaflow system and it sounds great.
Also, upgraded the head-unit w/ Apple CarPlay and a back up camera + XM radio. All in that was $700. Got the Sony XAVAX1000 model.
https://www.bestbuy.com/site/sony-6...-media-receiver-black/6283607.p?skuId=6283607
Here are some pics. 100% happy with it and totally recommend!
steve45
Well, I did it! I jinxed myself. Two days after posting this, the heater hose fitting blew on my 2009 Tahoe (about 185K). Fortunately, I was on my way to the water place and realized the problem about 2 blocks from it. I stopped to see what was going on and let it cool for a minute, then drove to the water place and got 3 gallons of water. I filled the radiator until water started pouring out. I jammed a couple of 3/8" socket extensions into broken hose and fitting. I got more water, then drove it a mile to my nephew's repair shop and let him have it.
It was a simple fix, but I just had too much going on to do it myself.
BadDaddy2003
