Newer OEM Rims Questions
B-Fox
I'm looking at a set of "2015" 1500 silverado "18 factory's. Wondering if they will fit my '99 4x4 tahoe. Both are 6 lug.
Any help is much appreciated
drakon543
Thanks for the reply.
Can't find no direct answer online
basically something your only going to find in the forums. but anyway as already stated yes they will fit not sure on the tire sizes for an 18 on a 99.
B-Fox
B-Fox
Thanks for the reply also.
I kinda wonder about the tire size (rubbing or not in turns) I'm sitting at stock height.
He's Asking $500 for these 2015 with good tread and great shape rims.
drakon543
as far as tire size unless he is running something other than stock tire it should be safe enough the run the tread out. if you notice a severe loss in wheel gap due to either tire height or the rim. sticking out farther just be a little extra cautious on the sweet jumps.
You've already received some good assessments from the folks here. If you want to take it one step further, specific to your truck, you may want to review the following.
Regarding wheel/tire combinations that will fit your truck without rubbing, no 2 trucks and their suspensions are exactly alike, due to a number of factors including accumulated wear on the suspension components, so there is no guarantee that what fits with no rubbing on one truck will automatically fit with no rubbing on your truck. Other folks' experiences can guide you in one direction or another, but the final test will be when you mount the wheel/tire combination on your own truck.
To assist you in getting a good idea on whether or not specific alternate wheel/tire combinations 'may' fit your truck with no rubbing, I recommend that you use the wheel/tire comparison app at the URL listed below. You can use this app starting with your existing wheel/tire combination as a benchmark, assuming that there are currently no rubbing issues with it, and measure the actual critical fender and suspension component clearances as directed by this app. Then, you can enter alternate wheel/tire combinations, and this app will give you the projected changes in these critical fender and suspension component clearances.
https://www.wheel-size.com/calc/
I used this app for determining whether on not I could use my current alternate wheel/tire combination, and it accurately projected the changes in critical clearances. Again, the use of this app in not an absolute guarantee that an alternate wheel/tire combination will fit without rubbing, but it provides a much better assessment, or projection, than simply an educated guess on your part, or a statement from others that it worked on a truck other than yours.
B-Fox
B-Fox
Very much appreciate the app link. I will check it out.
1BADI5
DMV
Yeah I was running '13 Silverado Z71 wheels with some 285/65-18 on my 99
bigdog9191999
sw michigan
yep use the size calculator for your current size and the size on the new wheels. as long as it is close it should fit with no issues. the offset may be just a touch different. but not enough to cause much headache.
EddieC
I believe the newer ones might be 1/2" wider but the offset adjusts to a degree for that. The wheels specs are easy to find to make an assessment. I did not feel it would be an issue on my '08 but when the pandemic came the prices for "take-offs" went crazy and I kept mine and added nitrogen to solve the slow leaks.
B-Fox
B-Fox
Nice!
What's the deal on the slow leaks? My neighbor had a '15 and the factories wouldn't hold air. how many years were effected? I definitely don't want those years. Lol
rismt
I have a 98 Two Door 4x4 at stock height. See photo. I got a set of OEM stock brand new factory 2018 Silverado wheels & tires (Goodyear Wrangler P265/65R18) from a local dealer as take off's when one of their customers wanted custom wheels. They fit and drive great. Hope this info helps. Bob
B-Fox
B-Fox
Very nice, they look beautiful on yours.
Thanks for the help on this. You all have been a big help. I hope I can contribute info one day.
TxVet33
Abilene, TX
Be sure t check offset. Stamped inside of rim
B-Fox
B-Fox
What's a going price on factories off a 2018+?
I have no doubt that you will contribute. If you move ahead with your project and report back on the results (including any challenges and associated workarounds), you will have made your first contribution. Knowledge is power.
CKendrick
