HELP steering rack bushing replacement
Mickey_7106
Bay Area
Trying to install this poly bushing on the passenger side. Been wrestling it for 20 minutes and it won't budge. Any ideas?
Mickey_7106
Mickey_7106
Bay Area
The poly bushing is much thicker. There's no way this is going to fit. Anyone had success installing one of these?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Even if you cut it slightly short to finally get it in there by length, it looks to be thicker and may also be a bear to still circle the rack and go in there. If you do cut a tad too short on the length, the rest of the circle of the bushing should still protect the rack.
Mickey_7106
Mickey_7106
Bay Area
This bushing is much harder than the rubber one. Its pretty hard to get one edge through as it is.
I'm done with this. I DO NOT RECCOMEND this product. I ordered another rubber bushing for $15 that gets here tomorrow.
After i trimmed it it still took a little wrestling to have it sit on on the bracket. Now it wont slide over on the rack. This bushing is just too thick. I would have to trim some more just to get it to slide over.
Looks like you need a cylinder flex hone tool to finish the job. Does the new parts come with any warning like, "Some trimming may be required"?
View attachment 270645 View attachment 270646 View attachment 270647
looks like you need to put that rubber boot on first then slide the rack in
08grey
I did this bushing and it kicked my but you have to take a crow bar to the ear and over the face of the bracket and wedge it on there once its on get a 2/4 and a sledge and wack it on keep beating it till its in place. Don't give up I didn't trim mine
Sent from my SM-G973U1 using Tapatalk
Mickey_7106
Mickey_7106
Bay Area
Well I wanted to see how much i needed to trim for it to fit. Even with all this trimmed still nothing.
Mickey_7106
Mickey_7106
Bay Area
Screw all that, this thing is not worth it. Rather put my effort in fabricating something like this. It'll serve the same purpose
briannorris
