01 Tahoe tune incoming, what (cold) air filter and exhaust?
Tonny
Tonny
Netherlands
According to AEM's website, that should fit your truck. I never looked into it, but, apparently, all of these trucks from '99 to '20 take the same filter.
Great, thanks mate. Will order that filter asap before Brexit will **** everything up haha
Tonny
Tonny
Netherlands
And does anyone know what the difference in the Airaid MIT's are for mechanical and non mechanical cooling? Is it because it will hit the mech-fan or is it because of radiator space? I would like to know if I can order the e-fan MIT 200-919 for e-fans? I haven't been able to find a second hand e-fans, so that will come as soon as I will find a decent set. But knowing I want to go e-fan, I'm not really want to order the MIT twice. 200-912 is the mech one..
200-912: https://www.airaid.com/200-912-airaid-modular-intake-tube
200-919: https://www.airaid.com/200-919-airaid-modular-intake-tube
It's hard to see in the pictures, but the 200-919 one looks like it has less dept, but that is it with pictures, always hard to make decisions based on photo's.
Yes, the shape of the tube is formed to clear the electric fans. I'd imagine that the one meant for the e-fans would fit with a mechanical clutch fan, but the one for the clutch fan won't fit with e-fans. So, you should be able to install it if you get it before the fans.
Tonny
Tonny
Netherlands
Cool, i'll just go for the 200-919 since I will stay searching for e-fans, easy mod to release some more horses and torque, but not sure when I will find one.. But then I know what to choose from :) THanks
Tonny
Tonny
Netherlands
https://www.rockauto.com/en/moreinfo.php?pk=4656276&cc=1431156&jsn=780&jsn=780 I'm looking at new coolfans for 2005 Tahoe models for example. This will cost me including shipping and taxes about €250. Finally got a decent calculator now. But it is a unknown Brand. Though you also never know what a second hand e-fan will do. Haven't found one yet so I don't know how much they will cost second hand in the Netherlands when one comes by on the market places..
EDIT: Because I've the smaller 34,50 inch radiator, a Corvetto e-fan may fit I read somewhere? https://www.rockauto.com/en/moreinfo.php?pk=1407685&cc=1368356&jsn=654
This one is 28,08 width. Because otherwise my hoses will be in the way. Just took a look under the hood, the shroud might be in the way for the Airaid 200-919. But since it has already been cut, I wouldn't mind another little cut if necessary. Can't say that it looks it will hit the fan otherwise. Here some pictures. One reason to remove the LPG is also all the computers and extra hoses that are now under the engine. I like it as tight as possible. And my system is kinda two times a 4 cilinder LPG package on each side with 4 injectors.
Some photo's, finally the sun is out since a week :D
ATTACH]
diLucca
Bratislava, SLOVAKIA
ATTACH]
WOW, thats the maybe most horrible LPG install I saw, I bet the installer also drill hole into rear fender for tank cap.
Tonny
Tonny
Netherlands
Tube for mechanical fan has narrower shape to clear fan shroud.
I’ll just cut a piece out of the shroud.
Yeah the previous owner got the cheapest one. The evaporator is too small, cutting at 3000rpm and jumping to gasoline. And since I like the power a lot more on gasoline and continuing driving on LPG will eventually need new valves and head repair after like 150k. Because the first Vortec engines don’t have hardened valves! And it will lighter my truck up more and can make a proper engine bay :)
diLucca
But first check if it will clear also fan :)
I thought the old small blocks with iron heads does not have hardened valve seat.
With LPG the problematic were some heads from 2003 year with bad casting.
Mine were on LPG for 10y, so hope for no damage :(
But yeah, after tune I got almost same MPG as I have in WJ Grand Cherokee. And now with cheaper fuel in EU, I have not used LPG for almost a year.
Tonny
Tonny
Netherlands
Hahah yes I will. If the product is here, it will be worth a lot haha.
Na the 5.7 do better on LPG, but maybe I talk about the older 350's, out of the 80s for example. But I don't know that stuff yet. LPG is very cheap here in NL, 60ish cent per liter and 98 is €1,60ish. But will drive motorcycle more to compensate. And upgrading will cost like 800 and deleting 400. Then I will try to sell the parts.
Well my LPG guy said he knew about the 5.3 head issues. But he didn't mention which years. I believe since the 2003 flexfuel version they have hardened valves... but not sure mate
Tonny
Tonny
Netherlands
My engine ran gasoline untill 220ish km and I just past 300k kilometers. And have a valve fluid system but that one sucks also and no one really believes in that
Tonny
Tonny
Netherlands
I've done some picture research but and some other forums but it's actually the other way around. The Airaid for mech is indeed made to clear the shroud, but also goes higher, just like the OEM MIT. I can obviously cut the shroud but the blades of the fan are very close to that and I think those will be in the way to be able to fit the Airaid for e-fans. All though everybody says it doesn't really matter, and I could keep using the mech version when swapping to e-fans.....but.... if the mech version would be optimal, they wouldn't made a one for the e-fan. Could be also marketing but on the outside they a really different, and I can imagine in the inside as well. So I think it's better to wait until I found a e-fan and then go with the Airaid 200-919. Good way to test my patience, haha.
And luckily they didn't cut in my car for the LPG valve, it just comes out at the back, would not be allowed anymore now but because of the installation year I don't have problems with the APK(MOT)! But I already starting driving on gasoline now, just waiting for money to let a shop delete the system and make the wiring stock again :) Will lose a lot of weight also then, and less weight is more speeeed
Tonny
Tonny
Netherlands
I have the smaller radiator as mentioned. But read stories about the LS1 Corvette 1998+ those fans fit the smaller radiator? So was browsing ebay and came acros this: Would this not be a option, maybe with some custom fitment I'm not afraid for... https://www.ebay.de/itm/Engine-Cool...368056&hash=item5468b0fdf6:g:0ocAAOSwvspbgXMf
What ya guys reckon? This is affordable with shipping and taxes. There are more similar fans available in different price ranges on ebay.. And will this work with a Tahoe wire tree or can I use the LS1 wire set?
I have the smaller radiator as mentioned. But read stories about the LS1 Corvette 1998+ those fans fit the smaller radiator? So was browsing ebay and came acros this: Would this not be a option, maybe with some custom fitment I'm not afraid for... https://www.ebay.de/itm/Engine-Cooling-Fan-Assembly-620-634-For-Camaro-2002-98-Corvette-2004-98-Firebird/362533682678?fits=Model:Corvette&epid=74368056&hash=item5468b0fdf6:g:0ocAAOSwvspbgXMf
If that's what is designed to fit your radiator, then I don't see why not. Worst case is you'll have to use the Tahoe fan harness and splice on the correct plug ends for those fans or make the LS1 fan harness fit the Tahoe.
Tonny
Tonny
Netherlands
Well it's a little difficult to figure out. But when I just got the Tahoe, the radiator broke. I then found one in the Netherlands, replacement for Silverado/Avalanche/Suburban. Just when starting installing, me and my mate saw that the radiator was smaller so like wth. But then we found out there also fits a smaller radiator in the Tahoe, fitting the OEM smaller bracket holes. Only thing we had to do was cut he fan shroud for the hoses. And I already watched some e-fan conversion video's. They all have the OEM size radiator. And you see the e-fan will come in between all the hoses. So that means a OEM size e-fan won't fit.
Let me find some photo's if I've them:
Temperatures are holding fine, even in the 2018 summer, which was one of the hottest summers since 100 year.
Can't find my cutted fan shroud but I think you will understand it. Normally the hoses are also outside the fan-shroud, but mine where now inside so had to gut some pieces out for the hoses.
EDIT:
Tonny
Tonny
Netherlands
Here in this video he has small RAD and small efans(maybe from corvette):
Or use this:
https://www.flex-a-lite.com/electri...let-truck-with-27-1-2-inch-radiator-core.html
Or do it "redneckstyle", just screw into radiator fins, i think some Skoda, or old french cars has it like that :)
Sorry mistake in translation, we still have her, in may she will be 4years old.
**** somehow I ended up seeing an other video then this one. Just saw this video, and got the answer to my own question. This will do fine!! So come on Dutch people, buy my stuff from the marketplace so I can do mods hahah
Ossipeelake
