HVAC Control Head?
malmed
The part number in your pic was replaced by 89018365, which is what I replaced my bad original (52402588) with in my 04 with auto climate.
The lower one near the 'hump"?
mattbta
Frisco, TX
I did that one in 2012. This time I had to do passenger side, which was buried under the dash cover. Same part # for me.
JonnyTahoe
Minneapolis
Original problem was only hot air blowing out of drivers vents.... I installed a 'new' used digital control unit, recalibrated, and the actuator still does not move... I cannot install it because the slot is in the wrong position... the door it controls only moves about 1/4 turn and the slot in the actuator will not line up with the position of the door.... but, just hanging there, plugged in, it never moves, and it is my second new one, neither moves.... all fuses are good... I don't know what to try next....
I feel your pain. Was having the same issue with the Mode Actuator (Computer Climate Control) Used actuator worked for five seconds. New actuator (AC Delco Brand New) worked for five seconds. NOT going to buy a tech-2 because I shouldn't have too. Have it set manually so heat comes out of the vents only but does the job and gets nice and warm. Truck has had electrical issues in the past. Might try a used head unit and that will be the last attempt. Heater works great and I have plenty of warm socks.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I fought this same fight with our 02 Envoy for 3 years. Went through four different actuators. They would work for 5 seconds and then quit. The wife was out of patience for it. I cam really close to making a lever and using a lawnmower throttle cable to control the modes. The damn truck would not self calibrate the actuators. Once I got a tech2 I had it fixed in an hour. I shouldn’t have needed the tech2 but I certainly needed it.
JonnyTahoe
Minneapolis
I have thought about rigging something up as well. Back in the day we never had this crap happen. Yours never recalibrated and I'm sure mine won't either.
drdave81
drdave81
Waterford, MI
No problems removing the used ones from the junk yard trucks or installing them in your truck? No problems getting the new one lined up properly? I had all kinds of problems.
Sorry, just now saw this. Oh it was no fun getting it lined up, it took a few tries, but eventually I did manage to get it.
OneofFew
Talullah Falls, Ga
I am struggling with the same issue. Failing mode actuator would only go half way. The replacement did everything backasswards. vent in defrost mode, no movement in between, defrost in vent mode.
I went through several calibration techniques I found and never would they actually go through their sweeps.
I wish I had a tech2.
OneofFew
Talullah Falls, Ga
The 'mode door actuator' you have to rotate a little to line if up with the shaft it slides on and then trun it to where the mounts line up. The heater control actuator 'blend door' is easier to line up if you turn the blend door a little by hand. In both cases you have to make sure your actuator is within its movement range indicated by the marks. If it's out of that range, you have to turn the motor in the actuator on the bench with jumpers. There's a video by ACDelco on this on utube.
George B
¯\_(ツ)_/¯
These are all good points but if the truck doesn’t see the counts from the position sensor it will fail calibration. Thats what mine was doing. It wouldn't see the counts correctly.
JonnyTahoe
Minneapolis
So my new Actuator may still work if I put it back to where it was originally before I ''Tested'' it before bolting it in place ?
JonnyTahoe
Minneapolis
I figured it out after I removed the drivers seat so I could stretch out inside the truck instead of kneeling outside the truck and reaching up to install it(mode actuator).
malmed
Either all three of the 02 actuators were bad or GM changed something over the years. Maybe you have the wrong actuator model?
THIS was my problem. I bought the correct model actuator used even, and it worked first try, no calibration needed, plugged in and it worked.
Thank you Fjs0001 :)
I had bought a "new replacement" off ebay and off amazon that matched my actuator number "supposedly".... they did NOT.
Problem solved, no more hot air goming out drivers side only, all the time :)
Conedaddy
