Rear coil springs 2 different GM style
Woodblocker55
Woodblocker55
Next someone can tell me how raise.front end without messing up my nice ride . Do just get new torsion bars? Or crank the torsion bars tighter??
Sent from my LGL722DL using Tapatalk
mwilson62000
Senior Member
Ykk are in my 2006 yukon xl slt option 2 .HD .
[emoji848] I know there constant rate because I put a set of regular shocks on them. I know they're the HD because like when gas is empty my back end is up in the air. And heavy trailer no saging . Remember my is slt option 2 with 4:10 gears . There wasn't as many in 2006 there was more in 2005 . I got air bags I just need to install them .
Thanks.
I wasn’t sure whether to go with constant or variable rate. Since I have regular shocks I should go with constant I’m assuming. May order both HD and regular moog and see which ones work best. Currently ride height is just over 14” to the bottom of the hitch.
mwilson62000
Senior Member
wish I could help you on that, but don’t know. Would like to know this also. Hopefully someone knowledgeable will chime in.
Buford bubba
