Leveling a '21 with Air-Ride Suspension
Swatdoc
He guys I'd like to level our Yukon Denali. Preferably I'd like to raise the front a tad as compared to lowering the rear.
I would imaging there are some type of ride height sensors which would make this not just a simple thing, or is it?
BTSRT
contact edgymods - John will set you up with suspension links (raise and lower). MY 2021 Escalade is currently lowered 3".
S
Swatdoc
Excellent - and just to confirm, you also have the air ride suspension?
BTSRT
Yes - there adjustable links for each sensor - Takes 20 minutes to install. You will NOT need to jack the vehicle up or take the wheels...Very Simple install
S
Swatdoc
Perfect. Couldn’t ask to be much easier.
I’m in contact with John at Edgymods. Just gotta decide for sure if I want to lower the back or raise the front. looks to be about an inch difference so it shouldn’t take much to level it
BTSRT
3" drop - sitting at entry/exit height.
WILWOOD and WHIPPLE - Hurry up with your kits!
BTSRT
Swatdoc - I would absolutely lower the rear. I'm a sport truck kind of guy :)
S
Swatdoc
We will be towing a small toy hauler - about 4K lbs. would lowering the rear compromise that at all do u think?
BTSRT
Thank you - Just installed corsa muffler - sounds amazing
PresidentiaDenali
Hey wondering as it seems its been sometime since your install, have you had any issue? also how has your alignment been throughout?
Conedaddy
