5.7 oil filter
pedub
Hello, I got a 2000 tahoe z71 obs, I changed the oil and the oil filter was a short one, the manual says it should take 6 qts ? but it was 5 qts, should I be using a long filter? and do all ac delco filters have a check valve? thanks
wjburken
Eastern Iowa
Don’t think a long filter has a qt more capacity than a short filter. You might have mis-read the manual as I think they only take 5 qts.
GMT800 2005 Tahoe Z71
Navy Supporting Member
5.7 engine is 5 quarts and the 5.3 engine is 6 quarts. The manual is likely generic and says what is for the 5.3. You are supposed to put in 5 quarts and then check level and add as needed anyway.
pedub
pedub
yes every 350 I ever owned was 5 qt and thats what I put in it. yes I agree the manual must be generic, any reason I should be using a long filter?
I use a longer filter just because I want more oil capacity. Plus, typically a longer filter than the application calls for is labeled as "heavy Duty" and we all know that is a good thing. Kind of like heavy duty shocks and heavy duty toilet paper, yea, that's a good thing too.
drakon543
2000 is the mid year so there was some 5.7 models instead of the 5.3 5qts is correct for the 5.7. well maybe a shy more if you had it sitting a while and you had the front raised up significantly you might fit another 1/4 qt if you brought it straight to the top of the fill line.
JonnyTahoe
Minneapolis
GM put the remaining 5.7's in the OBS '00 trucks (Z71 and Limited).
Wylie_Tahoe
IIRC, the PF47 is the short filter and the PF51 is the long filter. There is not a 1 qt difference there. With that said, I always prefer the larger filter when it fits. I run the longer filter on my 03 5.3L
jk6062
