2008 Yukon Denali - weird issue
ktsanf
Hi all, first post. Have a very weird issue going on with my 2008 Yukon Denali. Front blower started acting weird, so I replaced the blower motor resistor. The weird part was it didn’t work at all after replacing, and then started working about two hours later, and has been fine for a while. Then it did something different where the fan would run without the car running. So I replaced the blower motor resistor again, and it’s been fine for quite a while. But now I have no front blower fan at all (The fan display works where it shows the fan going from low to high). The front fan does not run, but the rear blower does. Took the blower motor out of the front and put power to it and it spins fine. Fuses are fine. I’m thinking the HVAC control module? I searched through out the forum and couldn’t find anything similar to this problem.
Appreciate it greatly if anybody has any ideas what to do on this craziness....
CaptainAmerica1
Arlington TX
Check the resister again. If it was the control module I assume the rear would exhibit the same symptoms as the front. You’ve checked everything else and the resister is easy enough to check with a dvom so I’d start there.
St. Louis
The fan running after vehicle is shut off sounds like the afterblow function was enabled, which can only be done by a dealer or someone with a two-way diagnistic tool such as a Tech2.
There was a TSB about it. Have you ever taken it in due to a musty smell from the air vents?
Welcome to the Forum from NH.
Pics, please.
Other folks will chime in with their suggestions.
K
ktsanf
Thanks for the reply. I was going to try that as well. I think I may try a new blower motor because when I had the existing one out it was sort of hard to turn. I read elsewhere online that if the blower motor is failing it might be using more power than usual and causing issues with the resistor. I know it wasn’t spinning freely by hand and I thought it was odd that it needed a little bit of force. Luckily, my brother owns an auto parts store.
K
ktsanf
Thanks for the info. There’s been no musty smell at all and no one has touched the vehicle since we’ve owned it.
petethepug
Michael
SoCal
Sounds like a bearing on its way out on the fan. If there’s any resistance on the motor you pretty much nailed one of the problems in the issue.
In my other car the resistor pack is the first thing to go when the supply fan is going out. Strangely the fuse never goes, the resistor pack goes first. Clean off your evap coils when you’re in there, if possible. It’s also a good time to add the cabin air filter when all is apart.
91RS
GA
It isn't a resistor if it has auto HVAC it is a blower motor control module. Did you buy a GM one or aftermarket? I would buy a GM one if you bought an aftermarket one.
K
ktsanf
Thanks for the reply. Yeah, it needs force to spin it. I just replaced it and so far all good......
K
ktsanf
Correct, control module. I tried one after-market and one GM. Just replaced the blower motor, all good (so far......).
Thanks to everyone who has offered suggestions on this issue. Greatly appreciated.
02Lightning
I have the musty smell from the air vents, is there a TSB? What is the fix?
St. Louis
Not sure of the TSB #, but the dealer enables the afterblow function on the HVAC system.
This will run the blower fan for a certain amount of time after the vehicle is shut off and had the AC on. It's to help dry up any condensation in the ductwork.
02Lightning
Cool, I'll have to look into that.
Big Jim
