2007 GMC Yukon SLT re extended brake lines need for a 4 inch lift?
NSMTim
Toronto
Hey everyone, I’m new to this! Anyhow just got a 4 inch lift kit for my 2007 GMC Yukon SLT and wanted to know if I would need to get extended brake lines? And if yes then what brand what you recommend? If you have a part number that would be great. Thanks.
Big Mama
Virginia
Welcome to the forum from Virginia. How are you doing the lift? Spindles and springs or ? I’m not much help on this but that’ll be the first question.
NSMTim
NSMTim
Toronto
Thank you for the welcome. I’m starting with the ReadyLift 4” lift kit. It incorporates the factory suspension by using spacers on the top and bottom of the shock and In The rear the spring gets spacers. What was important to me is the new extended and re-angled ball joint controls arm, extended sway bar links and front transmission spacers. Eventually I will replace the suspension and it’s spacers with a proper 4” suspension lift. The plan is to have in the rear shocks with reservoirs and adjustable dampeners so that I can stiffen the ride for when I’m towing our boat. But for the lift I’m worried about over extending the factory brake lines when I go off-roading and start flexing. So I’m reaching out to any and everyone for advice.
Welcome to the Forum from NH.
Pics, please.
My truck is stock height, so I cannot help you with your question.
Other folks will chime in.
NSMTim
NSMTim
Toronto
Pics, please.
K I’ll post a before and after pictures. But I have the ReadyLift 2.25 leaving kit with 33” K02 tires. Plus a westin winch tray with a modded RoughCountry bull bar and a 10,000 lbs winch on the front!!! Lol lots of work done and even more to be done! Lol. Tomorrow I’ll post a pic. But to fallow the progress check out “416 Expedition”
PS I really like the dual exhaust on your Yukon. Looks really good.
NSMTim
NSMTim
Toronto
AB1D7283-D915-4F37-98FD-57B13C23952B.jpeg 903A4D4F-F66E-45AB-AC06-3846DABDFB83.jpeg C6BA3AC0-F4ED-4698-AC2F-2398C500D009.jpeg 2F66E199-FC84-43AE-95EC-FD213D0D8712.jpeg
The dual exhaust, one on each side, was the reason that I chose that specific exhaust system.
Tozan
Overlander
Beauregard, Louisiana
Well I have the answer for him a year later...
You will need longer rubber brake lines in the rear or the differential brake line bracket will break causing the steel lines to break too.
Then you will have no brakes...
I tried replacing my bracket with a heavy duty 1/4 inch bracket... It was taller but, it also broke and now I have broken my third and fourth brake lines.
I think the two rubber lines are stretching tight this causes the bracket to break from flexing and fatigue. Then steel lines start flexing and they will break too.
I think what it needs are two longer rubber lines.. Anyone have a source for those?
if you have any kind of hydraulic shop in town or a good hardware store or even a tractor/trailer supply they can make lines for you, crapp ton of farm land around me and fertilizer eats brake lines so there is several places here that can make them on the spot.
plenty of places online as well, oddly enough a google search finds them near me
https://www.trivalleyhose.com/home
https://galferusa.com/products/custom-line-builder -- there in carson city
I didn't know that you joined the forum here! Enjoyed watching your youtube off-roading videos.
Our Sierra has a 6.5" lift and the instructions called for taking the brake lines off of the brackets so they can move around more. Been that way for eight years or so now.
Bill 1960
Testing the Limits
My ProComp lift has a relocation bracket that dropped the rear connector block and changed the angle to orient the the flexible hoses more downward IIRC. I’ve had no issues to date and it’s been flexed a LOT.
With respect to the OP (and not slamming the product he bought, I’m not familiar with it) I found in my research that one of the differentiators between the low cost kits and the more expensive solutions was the inclusion of parts to resolve things like brake lines.
Tozan
Overlander
Wich connector block was relocated? I have two blocks on mine one is above a frame rail and the other is attached to the differential. I wonder if the upper block above the frame rail needs to be lowered below the frame?
@swathdiver So are your steel lines just moving up and down too? On mine when ever the bracket on the diff breaks the left steel line ends up snapping in two.
My rig gets pretty maxed out flex wise and is driven about 30 miles a week on unmaintained trails.
I would like to get around 15 inches of travel in the back end and may end up putting a limiter on the differential to keep it from dropping as much while still allowing the wheels to flex.
Bill 1960
Testing the Limits
I will get you a photo and post it later. As I recall I moved the upper block from above the cross member to below (Or maybe beside?). The bracket they supplied you could easily duplicate from hardware store bits and there’s pictures in the ProComp installation instructions.
The major pain as I remember was getting the block unbolted from the crossmember working in the confines between the frame and the floor pan.
Tozan
Overlander
@Bill 1960 it is pretty tight in there. I wish I had a lift in my garage... For that matter I wish this garage had a taller roof so I could jack it up more than a foot or two... lol
Tozan
Overlander
I fixed it for now. Since I was replacing both lines I was able to bend them to fit the new location.
I hope this will last for a while but either way I am going to try and order a new set of SS lines to replace the stock rubber lines.
Sucks I have to move it outside when I jack it up... I miss my old warehouse in Reno with the 45 foot ceiling and car lifts. But, living in the middle of nowhere is well worth it...
Drewphil
