2011 tahoe 2" front leveling kit
ACIE ELLIOTT
Hampton, VA
I was wondering what is the biggest tire I will be able to run with 2" rough country front leveling kit? I'll be using my stock 20" wheels l.
Thanks
Acie Elliott
Big Mama
Virginia
Welcome to the forum from Virginia. Can’t help on lifted rigs but others will chime in. Nice truck.
RooTBeeRthe1st
I don't have 20's, but I fit 285/70R17 mickey thompson baja atz p3 (factory 17x7.5-31mm wheels) with a 2" leveling kit with minor fender liner rubbing under compression while turning.
and the sidewalls are flush with the fenders, no poke!
46503661_10216221831151636_5649785175853236224_o.jpg 46749158_10216221746309515_7057355871260508160_o.jpg 48426716_10216441141714263_4780542116503748608_o.jpg IMG_20191128_103031018_HDR.jpg
PG01
Up here to the right
Thanks
Acie Elliott
not sure if op is still looking but I know people have 305/50/20 no rub on stock suspension.... street tires tho, not an aggressive a/t tire.
That said I have 285/70/17 a/t-ish tire and have very little rub in reverse at full lock with a 2” level.
check this out, you can prob do this without too much trouble....heating and bending fender liners is common
Candielaine
