Someone Help
Vic Tha DON
One of the shock extenders broke on a tahoe I recently bought. Can I uninstall the extenders and put the shock back into its stock positions without damage?
V
Vic Tha DON
Shouldn’t be a problem. How long is your extender? Are they the OEM shocks?
The extenders parts number are mmc-33070...i believe they are OEM
drakon543
yes you should be able to reinstall your shocks without them. until you get them replaced steer clear of any action that would cause your shock to be compressed beyond casual driving situations. im not going to read an article about something im already aware you should try to avoid. either way slamming the shock piston into its own parts with the weight of a vehicle behind is always a bad idea. just as long as you have more than 2 inches of shock travel calm casual driving avoiding pot holes and any sweet jumps and you should be ok. still get it fixed right
Jason in DLH
Cheeseburger and Fries
MN
This is probably why I had to replace my shocks last year as I installed coil spacers for a small lift and didn’t bother changing the shocks. I did replace them with longer Rancho shocks at the time to be safe (thankfully I did!).
You’ll be fine for awhile, just drive over big bumps carefully so your shocks don’t bottom out like James said.
CKendrick
