What part number is this nut under silplate
ramchol76
Hi All
Need help with identifying the part # of the nut fitting the bolt (circled in picture) which holds the wiring under sil plate, any alternative nut spec if known is fine as well.
thanks
Hi All
thanks
Take one off the other side, go to your local hardware store, and match it up. 20 cents vs 6.00.
St. Louis
I have a few black ones sitting on my work bench I've had for years that came with some mud flaps (I think) I got years ago.
I also just took down and gutted all my fluorescent light fixtures in my garage and replaced with LED strips. Each ballast in each fixture was secured with 1 or 2 of these, depending on the fixture style.
I think they're the same size
This is only half of them....
veteran111
