SnowDrifter
Dot 4 LV works better with abs for what it's worth. Minor, but there.DOT 4 has a higher boiling point than DOT 3 so it’s more heat resistant.
It is has higher viscosity so it works better with antilock brakes.
https://www.google.com/amp/s/blog.amsoil.com/dot-3-and-dot-4-brake-fluid-whats-the-difference/amp/
That being said enough of the stuff is dot 3/4 now so YMMV
Unless you have stabikitrac or Awd, rear lines are a shared circuit with the split at the diff. First one will take a while to see clean fluid. Second, much faster
Reservoir is about a quart. And if you flush to clean on all 4 corners, it'll take about another quart.
You can go lazy and just open the bleeder and let them drip. Pedal bleed for a couple pumps per caliper all around and you're set
Don't run your res dry, and don't pour fluid in it while you have a bleeder open. More apt to suck in an errant bubble introduced from pouring
