@Sam Harris are you still looking for efans? I'm going to visit one of the UPulls either tomorrow or next weekend to pick up some things, and I could look for you. Either Aurora or Denver. The one out on Santa Fe Dr nearest me seems to be the worst of the three, so I typically don't go there even though it's closer.
I'm not clear, though on if the NNBS fans would work. Otherwise looking at '05-'06.
Yup, nnbs fans work, according to @Doubeleive up to 2014 will work. Happy hunting!
Sam Harris
Hell yeah brother! I am. I was planning to buy new, but if you can find some for me, that would be kickass! I was still looking for a damn part number. Lol
Will do. If I see any decent ones I'll pull them. With the cold weather coming in I probably won't go until next weekend.
Dantheman1540
Sugar Loaf Mountain
Got into some WOT in the denali. All I can say is WOW! I've never ridden in anything with a big NA motor with a max effort sort of cam and heads. It's very fast for a 6klb brick on load E tires, I'm very happy it has hellwig sway bars. In a Camaro or vette this thing would be a rocket.
This was the only video I took, he didn't just wack the throttle but laid into it to keep it from spinning. I'm impressed it spins in second from a roll on a dry road, the Tahoe won't do that in the wet.
Also that chirp was from 2-3 not 1-2, first gear is even more savage but has no traction.
eohat
In Torque We Trust
Mike @ Altitude 5,280 ft.
For mine I picked up a heavy duty fan from a 2007 Tahoe with the 7/9 blade combo. I replaced the motors with new ACDelco units (Bosch). Here’s the part numbers if you need them.
Drivers side motor
https://www.amazon.com/ACDelco-15-80880-Original-Equipment-Cooling/dp/B000NW4O7K
Passenger side motor
https://www.amazon.com/ACDelco-15-80881-Original-Equipment-Cooling/dp/B000NWA55K
Pigtail (2)
https://www.amazon.com/ACDelco-PT2649-Equipment-Multi-Purpose-Connector/dp/B007QC2MSI
Keviebear86
Has anyone ever purchased a cover for your Tahoe? I'm currently looking for one since my truck will be sitting outside a lot this winter. I found a decent priced one around $150. Looks to be good quality, fleece lined and 5 layer protection. I just don't want the truck to sit out and get beat on this winter when I have no where to store it.
Sam Harris
Drivers side motor
Pigtail (2)
Awesome! Thanks sir!
people use them but other people seem to like them better and steal them a lot, some come with a option to use a cable lock under the truck, people can still cut that out but it's better than nothing. so I would look for one that can be locked.
Dantheman1540
Sugar Loaf Mountain
I honestly never thought of someone besides mother nature stealing a car cover. That's super scumbaggy
TheAutumnWind
cable lock just keeps kids and honest people out. You could cut that with $10 HF cutters that fit in a back pocket.
blueinkd
Dropped tank to blow out emissions lines. Replaced purge valve, vent solenoid and vapor canister. OEM vapor canister bit the dust and charcoal particles all in the lines. Noticed it when I replaced the piece on top of the intake, so my buddy said it was the best way to resolve the entire system.
Woodblocker55
View attachment 260887 View attachment 260888
How many miles were on the rig when it did that ?
Sent from my LGL722DL using Tapatalk
Must be something in the air. The last two times I refueled, I've had to let it trickle in or the handle would click off. It whistles the whole time gas is goin in. Currently shopping for all the parts and will drop the tank next time it's nearly empty.
blueinkd
224k miles. Pressure wash the exterior??? No?? Just going to get dirty in 5-10 miles. I only removed the emmision lines to blow them out with compressed air and remove any charcoal particles. Also blew back the line thats at the intake. Tank easy enough to drop when fuel pump is needed.
blueinkd
New black bow tie and bluetooth mod through the XM receiver. Sound quality is great from $16 amazon board. Will loom wires later. Been enjoying streaming my Spotify. That board is only good for audio. I saw some with built in mic for hands-free calling, but didn't care for that. 20201025_173853.jpg 20201025_173656.jpg
Merch619
